Mhz Gecko
  • jeff180
    • 150
    Mhz Gecko
    Does anyone have this boat? I've seen a lot of videos and in a lot of them the boat self rights itself when it flips over. I have a Pro Boat Mini v now and plan on running a
    .98 flex cable, 11.1 volt lipo, Mini hydro hardware ammo brushless motor pretty much like diegoboys except he used a mini cat and I think the mini v will have a stability issue when it hits top speed and then a wake comes along. So Im keeping my options open for the acceptance of poor handling.
    thanks
    sad
  • rhinopole
    • Jul 2007
    • 104
    I have a gecko. I run a golden horizons 4800kv motor on two TP 1320mah 2s packs run parallel for a total of 2640mah. With the batteries, ESC, receiver, and an additional 50gr. weight all on the left side, the boat does self right. I use a 31k
    graupner prop. This is a fun setup.
    • jeff180
      • 150
      The idea that it self right is great for me. even if I flip it on a wave or something it fixes it self.
      sad
      • rhinopole
        • Jul 2007
        • 104
        The trick is to have enough weight on the left side. The downside is that the boat will always lean to the left.....
        • jeff180
          • 150
          So then this is something I can do to my mini v right? But it will just track to the left or right which ever side I choose. I think thats okay at lower speeds but when you start hitting 30+ mph than you run into problems of it being uncontrollable
          sad
