Cat 32 twin- right Motor spinning when turning??? Why.. How to stop this.
  • Drax21
    • Jul 2011
    • 1077
    DSC_0739.jpgOk so I have my twin cat, and a DX3E Transmitter. I have the problem that every time I turn the right motor (looking from the back) keeps spinning. I'm guessing this has happened to someone before, Please help!
  • SJFE
    • 4867
    Check to see if your radio is set to mix channels. Some transmitters can be set to dial in steering to offset torque.
    • 785boats
      Wet Track Racing
      • 3423
      The throttle range in the ESC might be set slightly different to the other ESC. Reset the throttle ranges of both ESCs at the same time & see if that helps.
      Cheers.
      Paul.
      • Rumdog
        • 6667
        Uh, what's going on with your esc's in the pic? Are they 2 different esc's?
        • Drax21
          • Jul 2011
          • 1077
          No both 200amp Himodel Esc with custom water cooling
