counter rotating props!!
  • fastblack
    • 119
    hello two mates of mine are building two hpr mystic catamarans 115cm long, they will be using leopard 4082 2200kv x 2 , seaking 180amp esc x 2, 5 or 6s lipos 5000mah, x442 left and x442 right octura props.
    is this a nice setup and will they need extra caps on esc? also will they need 40c batteries minimum? i guess 5.5mm gold bullet connectors is minimum for motor esc and batteries? no deans here? what speeds too be expected?
    AND THE MOST IMPORTANT THING: should the counter rotating props rotate inwards towards each other(towards center rear of hull) or outwards away from each other?
    (hope you understand question im little bad in writing english)
  • dasboata
    • Dec 2010
    • 3972
    for the best speed set them up so they both turn to the inside For handling turn them to the outside this has been my understandoing good luck Chris
