1717 or 1520
  • Brushless01
    • Apr 2010
    • 489
    1717 or 1520
    Hi guys just ordered one of the flood hulls from Aeromarine laminates, what i was wondering is which motor to run ? i have already have purchased both motors. Also does anyone know what motor mount will work ?
    My goal is too have good speeds in the high 50's
    Thanks
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Brushless01
    • Apr 2010
    • 489
    Would this mount work ? http://southriverrcboats.com/shop/ar...WRP-4-25FLA%26
    • skellyo
      • Feb 2010
      • 596
      One of these would work better than just a single endbell mount:
      Fightercatracing.com is closed until Wednesday this week though so you won't be able to order from them until then.
      • Brushless01
        • Apr 2010
        • 489
        Thanks which motor do you think would work the best and give the higher top speed ?
        • steveo
          • 1595
          both motors will get in the 50's like you wanted i think then its a matter which will do it eaiser, i only own a 1520 and am about to pull the trigger in a 34" cat on 5s i think i should get 50 or close to and in an MM you should be able to break into the 60's with the smaller hull, there is a thread in the boat building section of someone using a 1717 in an MM
          • carlcisneros
            • Jan 2010
            • 1237
            Bushless, I use the lower motor mount from fightercat that skellyo listed there.
            works great.
            • Brushless01
              • Apr 2010
              • 489
              Thanks guys do you think that the 1717 and fightercat mount will fit under the modern cowl ?
              • skellyo
                • Feb 2010
                • 596
                Check out this thread regarding a MM with 1717:
                http://forums.offshoreelectrics.com/...highlight=1717
                • Brushless01
                  • Apr 2010
                  • 489
                  Thanks guys prop recommendations ?
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    1520 on 6s with an X445 to start and you'll be happy.
                    • Brushless01
                      • Apr 2010
                      • 489
                      Thanks but im most likely to use the 1717 as the 1520 is setup in my truggy.
                      • Rumdog
                        • 6667
                        1717 is wasted energy in that boat. Way too much power.
                        • Brushless01
                          • Apr 2010
                          • 489
                          ok thanks im going to go with the 1520 and fightercat mount and a Seaking 180.
