delta force 29
  • unlimited
    • Dec 2010
    • 14
    delta force 29
    recently aquired a delta force 29
    want to go a lot faster and looking for suggestions
    currentley has
    leopard 4074 _ 2150kv
    etti 125 esc
    running twin 3s lipos
    turning octura m447
  • Rumdog
    • 6667
    That setup is a recipe for destruction. I'm assuming you're running in series for 6s? That setup on 4s should get you well into the fifties.
    • driftah
      • 759
      I have that hull and run a 2200kv castle motor and octura x445 on 4s2p it hauls bud,that prop is better for larger setups you will smoke somethin
      • unlimited
        • Dec 2010
        • 14
        yes was running the lipos in series
        maybe will try with just one 4s lipo should make the boat lighter
        what size prop should i be looking at using?
        And are the seaking/ turnigy 180amp esc allright to use ?
        thanks for your help
        • unlimited
          • Dec 2010
          • 14
          thanks for the help
          probably why one of the batteries backed up
          are the turnigy/seaking 180 amp esc more suitable?
          currently using turnigy 5000mah batteries 40-50c discharge
          thankyou
          • Steven Vaccaro
            Administrator
            • 8934
            currentley has
            etti 125 esc
            turning octura m447
            Something isnt correct. that setup should run about 60-70mph for a few seconds before something blows up.
            Steven Vaccaro
            • unlimited
              • Dec 2010
              • 14
              hi there thanks for the reply
              what areas should i be looking at then as to why it may be underperforming ?
              goes slower than the dr 26 that i have had going at 56 kmh
              what sort of speed do the 29 run at on 4s ?
              thanks
              • Flying Scotsman
                Fast Electric Adict!
                • 5195
                Laddy, your original setup as has been stated is a recipe for disaster, now you are asking for help on 4S...were you running in parallel or in series in the original setup?
                I have a Delta 29 that runs on 4S power and speed is not my concern...stability...run time...motor and electronic safety are my priorities, and yes it goes faster than 56 kmh
                Douggie
                • unlimited
                  • Dec 2010
                  • 14
                  was running the original setup in series
                  noticed other users are achieving better results with less batteries
                  so i thought maybe it would be better to start lower down the voltage range and improve the handling of the boat
                  to try and figure out where i might be going wrong with my setup.
                  • Flying Scotsman
                    • 5195
                    OK, but that original setup would then have been a bit of the mark.....did you purchase this boat used with existing motor and drivetrain? There is something wrong in your setup. Tell us what batteries and hardware are now used or will be used in the future.
                    Douggie
                    • Scott T
                      • 625
                      Unlimited, post some pictures of your setup and it may help to diagnose any issues. As others have said, drop back to 4S, with at least 5,000 mAh capacity. An X442 should be plenty, or an X440/3. Check your speed control is giving you full power, and also check what timing you're running.
                      A Seaking 180 will be plenty for that setup if you wish to change, but check it will fit in the hull (they're pretty bulky).
                      I see you're in Queensland - which part? I'm on the northside of Brisbane and a member of 2 electric clubs. So there's plenty of help available if you're in the area.
                      Cheers,
                      Scott
                      Scott Tapsall
                      Pine Rivers Model Powerboat Club - Facebook Page
                      My Gallery
                      • unlimited
                        • Dec 2010
                        • 14
                        on the southside near coomera regatta lake
                        seen the gas boaters club down there on sunday a few months back
                        • Flying Scotsman
                          • 5195
                          Now we are getting to understand your issues but you Aussie twit is still not answering some questions..motor ..used ...new ... and other items, I think that Andy, the Doc or Paddy may have to bash on your door!!!
                          Douggie
                          • Heath M
                            • Mar 2008
                            • 865
                            Martin,
                            I have a DF 29 and with a feigao 8xl , m445 prop and 4s lipo, it was running in the 70kms,
                            Set your centre of gravity or balance point 260mm from the back of the transom, If the boat runs to loose/wild move your batteries forward a tad or if it is to wet/flat move them back a tad. Once you have a good running position worked out mark where the batties sit for future runs.
                            Hows ur strut set? Mine runs parallel with the bottom of the hull. The trailing edge of my trim tabs are level with the transom. Also try angling the turn fins up more, they might be dragging in the water to much.
                            Try these adjustments out on a 4s lipo and either a m442 or x440/3 prop like Scott suggested, if you still think you have speed problems then it might be a motor, speedy or battery problem.
                            Good luck and keep us posted.
                            Heath
                            ooh and ignore the previous posters posts, his just an old scottish twit
                            Brisbane,QLD, Aussie
                            • Flying Scotsman
                              • 5195
                              That last post brought a smile to my face.
                              Douggie, the old Scottish twit, who for some obscure reason likes marsupials!
