joysway x-blaze super version
  • the badger
    • Jul 2011
    • 18
    hi guy's
    newbie here i am looking for a fast boat. i am currenty flying my zagi on 3s lipos and i am after a fast rtr boat to run on 6s my zagi batts. (has to be fibreglass not abs)
    so the traxxas spartan is out.
    i have been looking at this http://www.hobby-paradise.com/en/pro...ml#DESCRIPTION what do you guys think.
    thanks in advance barry..
  • iamandrew
    • 576
    For that price, No way, thats seriously about a $100 hobbyking boat....
    • the badger
      • Jul 2011
      • 18
      any other recomendations i live in the uk so it would be better if i could buy it over here..
      • martin
        • 2881
        Speak with Bill Oxidean whose on this forum about the X Blaze, I believe he is racing the X Blaze & has very good things to say about them. Ripmax in the UK now has the X Blaze in stock but its the lower spec one with a smaller motor & esc, I believe they will also have the super version very soon. Its not recomended to run 6s on the super as the motor kv is to high & esc to low amp. Martin.
        • the badger
          • Jul 2011
          • 18
          hi martin thanks for the reply. but i have read that in the instructions you can run it on 4s and 6s and on some sites like http://tbmodel.en.made-in-china.com/...-Vee-Boat.html (an here) http://www.rc-hobbymodel.hk/_d271078399.htm can anyone confirm.
          there is not much info because there not out over in the uk till the 25 of this month...
          • martin
            • 2881
            Ive seen different specs on the 700 super X Blaze, Some say 6s others ive seen said 4s. I think youll find their arnt many on this forum that would run or recomend using 6s on this size motor & on a 90amp esc.
            • the badger
              • Jul 2011
              • 18
              is there any other rtr fibreglass 6s boats out there martin or is it traxxas only or is there one that can hit 50 mph range on 3s its just that i have many 3s for my zagi and didnt want to buy another load of lipo's.
              • sailr
                • 7128
                Bill is NOT using the stock motor. He likes the hull but is running a different motor and probably esc. So if you could buy it without the motor and esc and use your own it might be OK.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • sailr
                  • 7128
                  Our Starship will hit 50mph on 3S.
                  Mini Cat Racing USA
                  • echo75
                    • Jun 2011
                    • 7
                    I have the same boat and it is a joy to run, i have bashed it so much now i am really surprised that it has not fallen apart. Here is a video i made at a local pond in copenhagen, Denmark
                    • sailr
                      • 7128
                      You need a bigger pond!
                      Mini Cat Racing USA
                      • the badger
                        • Jul 2011
                        • 18
                        echo75 is that the super verion in your vid?. if so what battery's are you using ..
                        • driftah
                          • 759
                          how does this think work well with lipos both on one side???? balance etc
                          • echo75
                            • Jun 2011
                            • 7
                            I think it is the super version but i am not sure. As you can see from the video its FAST and even faster in a straight line so dare not try higher batteries.
                            Batteries i am using- 2 x 2S 7.4V lipo, 4000mah ,20 C
                            B4563 water cooling brushless motor
                            90A water cooling brushless ESCw/o BEC
                            CNC aluminum alloy rudder , trim tabs , knife and support
                            • echo75
                              • Jun 2011
                              • 7
                              Actually in mine the batteries are on each side and not on the same side as shown in the links above . (maybe they improved on this )
