Electrified recommendation-copied here
  • Chenige
    • Jul 2011
    • 201
    OK, been lurking here a little while and am ready to ask my big question. First, I built a Dumas wood atlas van lines sport 40 about 25 years ago. Have extensively modified it over the years with an OPS engine, etc. Have a Seaducer mono and a few other nitro boats. Put the boats away about 10 years ago due to kids.
    About 12 years ago I built up a bunch of Electrified "kits" for my nephews and nieces to build and made up a video building mine for them to watch. I think only one actually built it, but oh well. I have 4 more kits and my 12 year old daughter and 10 year old son want to build them. I figured I would build another for myself. My old one was built with a 19 turn speed gem motor, astro flight ESC and 1500 7.2V niCD. Surface drive.
    Electrified was a boat in the boat RC mag back then. 20" long. Mine scoots along pretty well. Does turn right which I think is due to prop walk so I need to revise somehow.
    So I would like to build with modern electrics which will introduce us into LiPO.
    I am looking for suggestions on batteries, motor, ESC. Here is what I think I have found on the forum. I am trying to keep cost down.:
    2 cell liPO Turnigy 5000mAh 2S 20C Lipo Pack
    450 motor ADS300 Water-cooled Brushless Outrunner 3000kv 300w (revised)
    ESC Seaking-25A Brushless ESC for Boat (Version 2.0)
    Anything else I should know?
    thanks, Chris
  • Boaterguy
    • 1779
    25A might not be enough esc, V * A = watts, if you want the 300 watts at 7.4 volts you'll be drawing about 40 amps, i'd go with a 50A ESC to be safe.
    have you chosen a prop yet?
    • Chenige
      • Jul 2011
      • 201
      How about one of these ESCs? The Turnigy is half the price of the SeaKing and can take 190A burst per website. Motor says it requires 30A ESC.
      ESC Seaking-60A Brushless ESC for Boat (Version 2.0) or Turnigy Marine 35A Brushless Boat ESC
      I have calculated run time with the above setup as 3 minutes. Does this sound reasonable? Would like to go longer. If I use your 300watt/7.4V I get 40 amp draw and only 1.5 minutes!
      5000mAH/60 min=83.3 mAH/min
      83.3 x 20C (from battery rating)=1666mAH/min Draw/min
      5000mAH/1666mAH/min=3 minutes
      Am I using the right calculations?
      On my current setup I am running a X435 but not sure what I would need for this setup.
      Am I even in the ballpark with my setup? Should I be using a different motor? i would like to get longer run times if possible.
      Thanks.
      • Boaterguy
        • 1779
        I don't really know all that, the 35 should hold up seeing as your max draw will be at 40A, I don't believe that a 35A esc will take 190A burst, but it will definitely take 40A+ bursts.
