Genesis handling problem help
  • Skullcracken
    • 728
    Got the Genesis running, 1250kv leopard X445 prop and T180 esc. Getting low to mid 50's. The problem I'm having is the boat has a constant pull to the right, even if I trim the rudder favoring left turning. Is it just the torque of the motor digging one sponson into the water?
  • Jabbo
    • Jul 2009
    • 495
    Sounds like it's prop walking I have the same problem with mine at those speeds it's a boat you have to drive.
    • Rumdog
      • 6667
      Raise the strut till its above the sponson bottoms around 1/8"
      • iamandrew
        • 576
        IF you keep raising the strut it will probably track better at high speeds but it will be even worse to turn
        • Rumdog
          • 6667
          That is not true at all.
          • iamandrew
            • 576
            Yeah it will if he is using the same rudder as what comes on the boat. The only thing i could come up with was that the water is hitting into the rudder bracket during turns, after lowering the strut the the x442 that i was using it started to handle a lot better
            • stadiumyamaha
              • 1371
              Im running 5s with a 1774kv and hitting 52-54mph with a x445. Its running straight as an arrow. strut and sponsons level, with no angle on the strut.
              • carlcisneros
                • Jan 2010
                • 1237
                took mine out for its' maiden voyage today (Fightercat Daytona) and it pulls to the right also.
                am going to shim the strut to the left (like an outboard turning left) to get it to run straight.
                tried raising the strut, a bit better, but worse in turns.
                lowered the strut, problem worsened a bit more.
                using CC1520 on 6S power. 642 prop. runs great tho and was chasing after one of the 40 nitro riggers with it today. :-)
                • Rumdog
                  • 6667
                  The inline rudder is the biggest issue here.
                  • carlcisneros
                    • Jan 2010
                    • 1237
                    I know, that is why I use an offset rudder.
                    • HOTWATER
                      • 2419
                      I had this problem with my Rico when trying to dial it in...Don Ferrette finally pointed out that the steering servo did not have enough torque or was on it's way out....changed to a servo with more torque and...wallah!!...problem fixed instantly and has NEVER come back!!
                      P.S. Make sure to at least use a 4/40 steering rod also....
                      -Kent
                      "Will race for cookies!"
                      IMPBA D12
                      My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
