electric conversion
  • wildjaych
    • 3
    electric conversion
    I have an old Kyosho Jet Stream 1000 about 40" long and I dont know what the weight is but its a plastic hull deep vee boat. I want to put an electric motor in it so I dont have to deal with the nitro mess and tuning anymore. I am into electric planes also so I know a little about brushless motors and lipos but I think boats are a lot different, from what I read anyway.
    Could someone help me with how to size a motor and speed control to fit this boat? Ive found a couple web sites that sell boat equipment but I am just more confused. I would like to get about 30-35 mph out of it like the nitro motor.
    This is kind of what I have figured in my reasearch, I will need:
    80-100 esc??
    Dont know how to size motor???
    3000-4000 20c lipo??
    Am I going in the right direction?
    Any help would be great.
    Thanks
    J
  • Avanti
    • 1280
    you will need big $$ stuff for a 40" hull check out the build section for a boat that size
    good luck with it.
    The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
    • ReddyWatts
      • 1700
      KB 45 9XL motor (1400kv) water cool it
      4S1p 5000mah 25 -30C lipo
      120 amp 6S controller
      M545 prop
      80 amps
      30 -35 mph
      20,000 rpm
      3.75 minute full discharge
      Lipo 80% discharge is 3 minute run time
      KB45 10XL (1200kv) water cool it
      6S1p 5000 mah 25-30C lipo
      120 amp 6S-7S controller
      X445 prop
      85 amps
      35-40 mph
      25000 rpm
      3.5 minute full discharge time
      Lipo 80% discharge is 2.8 minute run time
      ReddyWatts fleet photo
      • Avanti
        • 1280
        <4 minutes that sucks
        • SJFE
          • 4735
          Thats avarage for a fast boat. Lets not scare away the newb just yet . I know Kyosho hulls. This one is carries just a little more weight but is much more rigid than a Super Hawaii, which is about the same size. Reddy has the setup nailed as always. You can also run a set of 36mm 1800 to 2000kv L size motors. Two 100amp esc's on 4s-1p. 37 to 38mm props for around 70 to 80 amps. Run times around 5 minutes. My 2 cents anyway.
          • Avanti
            • 1280
            I never really timed myself but it seems like I run longer than 4 mins
            I'll have to bring a stop watch next time I run.
            • SJFE
              • 4735
              I can probably run 5 to 8 munites but thats running the packs to deep and risking damage. I need the stop watch & do the math my self. I have been getting carried away latley.
              • wildjaych
                • 3
                OK with all of this said. I would like about 8-10 minutes run time. Is there a brushed setup that could do what im asking. Maybe a double brushed setup?
                Reddy,
                I like the setup you gave me... but very pricey.....I would be better off with a new hull and electrics probably. Can you figure best brushed setup that you might know of. Maybe I could drop speed a little for a little more runtime???
                Thanks so far you guys have given good ideas.
                J
                • SJFE
                  • 4735
                  You can drop the 9xl to a 10 or 11 parallel a set of 4s 5000mah packs, srub off a few MPH and pick up or get very close to the run time you are looking for. It is a little pricy but large hulls always are. The advantage of being able to run in more water conditions is well worth it IMO.
                  • ReddyWatts
                    • 1700
                    This brushed setup can be run on 12 cells at 35 amps for 6 minutes on the 4s1p 5000mah It will run in the lower 20's in your 40 inch hull.
                    http://www.offshoreelectrics.com/pro...prod=ose-700sc
                    http://www.offshoreelectrics.com/pro...prod=hl-je600n
                    This is another brushless setup you can run on 12 cells at 35 amps for 6 minutes of run time on 4s1p lipos. Will probably run mid 20's.
                    http://www.offshoreelectrics.com/pro...qug7000&cat=42
                    http://www.offshoreelectrics.com/pro...prb3309&cat=75
                    Water cool motor and controller on both setups. The longer you run the hotter they will get.
                    *You can purchase a SV27 RTR boat and it will run with your nitro for a reasonable price.*
                    It will have a 5-8 minute run time depending on which batteries you purchase.
                    http://www.offshoreelectrics.com/products.php?cat=52
                    • wildjaych
                      • 3
                      After searching this site and others it looks like I can do this upgrade for about $120-130 dollars plus the cost of a battery.
                      Which motor is better? Aquacraft? Ferigo? Hextronic?
                      Also, This boat is a single prop, would it be better to run 2 motors through some sort of gearbox? on a single battery? or double battery? I havent seen any type of gearboxes on any of the site. What are my options there? Any info would be great.
                      Thanks for all the help.
                      J
                      • kin
                        • 55
                        J
                        my bet be the feigao ,,, but it really depends how u gonna set it up at the end of the day , what kinda lipos and props???
                        ~known is a droplet, unknown is the ocean~
                        • eboat
                          • 693
                          There is not enough room in this hull to worry about 2 motors
                          1 bigger motor and esc is better than 2 smaller motors and 2 esc's (and cheaper)
