Seaducer 40 and 60
  • skellyo
    • Feb 2010
    • 596
    Seaducer 40 and 60
    I have a buddy at work with some older (circa 1998) Seaducer hulls. They are both brand new. I was wondering if any of you had any experience with hulls from this time frame and if they're worth even looking into buying to make into FE monos.
  • v-spec
    • Jun 2009
    • 1046
    From the top they look the same as the current hulls but that doesn't mean they are where it counts.
    • Chilli
      • 3204
      The top deck is a little different than the current models. As a general rule with all Seaducers, if you get a good hull and you take the time to set them up correctly they run awsome. They are very sensitive to set up. For FE use they are high maintenance being very hard to tape down and with little interior room.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • carlcisneros
        • Jan 2010
        • 1237
        and you MUST also check the bow area inside. some of them have been known NOT so be glued up/re-enforced properly up
        in that area and have split open when is dunked.
