Hi any advice would be great to lifting the hull out of the water a little. I have a video of its first run, its very unstable on corners and dives at one point in the vid.
Specs are
32 inch Hull bought from Astec Models
2 Feigao 7XL (heavy)
2 Counter Rotating Threaded Flex Cables
2 X442 Props
Running in 4s 2 2s batteries connected in series at both ends
VIDEO http://www.youtube.com/watch?v=c2vIaSP7ZrQ&hd=1
Specs are
2 X442 Props
but I'm afraid it's correct.
Your little boat is heavy with those large XL motors, packs and ESCs. The CG should be about 3" behind the front of the hatch opening...but based on the video, where it is now may not be so bad. If you want to move the CG forward, put one pack in front of a motor, not both, an easy fix if needed.
