I've got an ICE 160 HV and I'm trying to get it to arm with a pistol grip. It's arming, but only at full reverse. Wondering if there's a way to get it to arm with the 70/30 position.
Does an ICE 160 require a Pistix?
FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Tags: None
I wonder if I can modify the springs on the trigger on the Tx... Hmmm. Since I have a few... might be worth a try... Going to give it a try. =)
I can get it to arm by holding the trigger on the ESC, so this might just work.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Done! Modified the trigger cam on the Tx to keep the trigger at the lowest point. It's a one way mod, but works like a charm.
If anyone wants info on this mod, let me know. It was on the Traxxas link 2.4ghz black Tx from an E-Maxx. I'm sure it would work on any of the traxxas pistol grips too.
Game on! =)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
there is even an easier way. A simple rubber band. then you can still use the tx for other boats.Steven Vaccaro
Cool, Yeah, that's certainly a way to get by in a pinch too! I've done that while bench testing some air ESC's.Originally posted by Steven Vaccaro View Postthere is even an easier way. A simple rubber band. then you can still use the tx for other boats.
Just don't use an old rubber band! (defaulting to 50% throttle on a bench test can make some really nasty sounds. )FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
