Aquacrfat 60amp ESC on 3s??
  • monojeff
    • Nov 2010
    • 2728
    I am wondering can this esc be run on 3s?
    Specs say:
    Input Voltage: 12-14 NiMh 4 Cell Lipo (8-20V inout w/o BEC)
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • 7512
    Nope, the LVC will kick in.
    • monojeff
      • Nov 2010
      • 2728
      I know but it says 8-20 w/o bec so if I run a separate pack will it still not work?
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • Diesel6401
        Memento Vivere
        • 4391
        bec has nothing to do with lvc. Two completely different things.
        Anything less then 4s the lvc will be triggered.
        - Diesel's Youtube
        - Diesel's Fleet
        • monojeff
          • Nov 2010
          • 2728
          So why does it say 8-20 then?
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • penz
            • 141
            The programing in the esc is only set to recognize 4s i would imagine, so 3s would be below the lvc threshold.
            LST XXL-4074 Taco, Slash 4x4-3660 Taco, Appparition-3674 Taco
            • monojeff
              • Nov 2010
              • 2728
              Just makes me wonder why they put the 8-20 in the specs.
              A bit confusing......
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • monojeff
                • Nov 2010
                • 2728
                Diesel while I have your attention I know you helped chud out with his esc.
                The one I'm getting will not arm correctly is this because of a bad cap?
                I have been trying to read about the cap issue but have not found to much info.
                I know how to do it I'm just wondering if it will fix the issue.
                Esc runs fine with separate receiver pack but without it won't arm correctly.
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • penz
                  • 141
                  If it has no bec then that's why it won't arm without a rx pack.
                  • monojeff
                    • Nov 2010
                    • 2728
                    It has a BEC but won't work while its connected.
                    If you unplug it then you can power it with a separate receiver pack and it runs fine.
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • penz
                      • 141
                      is it an internal or external bec? Sounds like the bec is possibly toast. I would pick up a $5 turnigy external bec and run it with that.
                      • monojeff
                        • Nov 2010
                        • 2728
                        It has an internal one but from what I have read these esc have had some issues with the caps that causes some issues with them and people have added xtra caps to them and fixed the problem.
                        I am not sure if the issue the one I am getting is the same or different problem.
                        I planned to run it with an external BEC but would be nice if I didn't have to and could fix it if possible.
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • penz
                          • 141
                          Oh I see. Well actually an external bec is a good thing, it takes away heat from the esc.
