T180 issues
  • steveo
    • 1595
    T180 issues
    ok last night i setup my esc to the servo to get the steering right and every think worked fine, then later on i hooked my new 4s battery and had a few sparks from trying to hook it up- now it wont harm with the rx. i check over and over for anything i was missing, then hooked the rx to a mamba esc and it worked then i noticed what looked like the red lead of the rx connector was pushing out and managed to get it to hold still nothing. so i cut back the esc wires thinking there was some damage and checked all with a meter. did the multiple sparking when connecting damage the esc?
  • siberianhusky
    • Dec 2009
    • 2206
    Do you have an external rx battery pack you can try it with?
    • steveo
      • 1595
      nah , you think the bec is dead?
      • siberianhusky
        • Dec 2009
        • 2206
        Who knows, could be a few things but that one is pretty easy to test, next thing I'd check would be the caps.
        Then try returning it.
        • steveo
          • 1595
          thanks i'll try it
          • steveo
            • 1595
            isnt there a wire i have to remove before doing this, if so which one
            • siberianhusky
              • Dec 2009
              • 2206
              Yep the positive wire from the esc to the rx
              • steveo
                • 1595
                thanks again
                • m4a1usr
                  Fast Electric Addict
                  • 2036
                  You can check to see if the caps are bad since you have a multi meter. Without any voltage connected do an resistance check. Accross the pos and neg leads you should get at least a couple meg, probably more. reading. Connect up the batteries, that will charge the caps and measure again. You should see a very low reading, like a couple ohms at most. If you have 4S voltage applied to the caps and you still see a resistance in the mega ohm range you got bad caps.
                  John
                  Change is the one Constant
                  • steveo
                    • 1595
                    yes it was a bad bec i wont bore you with the details is was a pain- now to get an rx pack one of the boats will be using 5s anyway maybe this was a good thing
