prop suggestions
  • video200
    • 840
    heard anything from joe ford about the response i got on the mail ?
    would realy be nice with a good anser on this so we all know what is coverd and not.
    • tonysmoke
      • Mar 2008
      • 1
      hi all tony from jersey channel islands here , new to this fast elec game could do with help, i have a cen wave shark 700 bb turbo, jeti speed con, 1.16th shaft,with dog drive running on two 8,4v can i use three blade props if so witch one thanks hope some one can help,
      • peells
        • 739
        speed control
        Klaus,
        I have heard nothing yet and have been waiting for a response as well, Steven Vacaro who owns the site or OSE any way he sells the things and has stated that 4s no problem, and one other guy said he ran 5s, I personally ran 6s without disconnecting the red wire and found nothing in the instructions saying that should take place.
        Peter Eells; Fun, and Helping others To Have Fun!!!
        http://rcboatsbypetere.blogspot.com/
        RC.Boats.by.Pete@gmail.com
        • G Doggett
          • 477
          It seems to have gone very quiet out there !!!
          No word yet from Castle.
          I might have to send a 'gentle' reminder over the weekend.
          Graham.
          • andym
            More Go Than Show Prop Co
            • 2454
            I have sent two 120's back for warranty that where run on 4s & 5s and had no probs with the warranty.
            • Steven Vaccaro
              Administrator
              • 8934
              I would not run 5s or 6s with the red wire connected. You should disconnect the bec.
              Steven Vaccaro
              • video200
                • 840
                Originally posted by G Doggett View Post
                I have sent an email to Joe Ford quoting the reply to Klaus.
                Watch this space for the reply.
                Graham.
                you heard from chastle yet ? if not somone need to go over there and ask them in persone.
                klaus
                • peells
                  • 739
                  Klaus read what Steven Vacaro has to say just above your post, I did not see in the instructions that you needed to disconnect the red wire but I guess it is par for the course. disconnect the red wire and run 4s or lower that should save you some grief over not burning up your ESC.
                  • video200
                    • 840
                    the question in hand here is not the bec but if the warranty aplyes for 4 cells and above as it say in the manual that it dont.
                    i asked castle about that before i orderd a hydra 240 and the reply was that the warranty aplyed BUT G Doggett spoke to chastle about 1 month before and got the totaly oppasit anser so we kinda qurius to witch of the reply`s is the one we should use sinse it is nice to know if we have a warranty or not.
                    if you read here http://www.castlecreations.com/suppo...user_guide.pdf on page 5 you can clearly se that the manual say that there is no warranty.
                    • peells
                      • 739
                      OK so no one else would do it here is the straight skinny right from Castle Creations, Forget what everyone else says Read this pdf I just downloaded today I highlighted one area in yellow and placed arrows in the other section of everyones interest. It docent matter what anyone else tells you what matters when you try and get warrantied is what is written in black and white!!! so without further delay feast your eyes on this. I had two pdf's but you can go to castle creations.com yourself and look up the hydra info your self
                      • ace028
                        • 986
                        Your file don't work.
                        Twin power =
                        • peells
                          • 739
                          good job video
                          • peells
                            • 739
                            yes it does double click it and then your computer will or should ask you if you want to save or open I just tested it!!!
                            • ace028
                              • 986
                              Ok, I was using the default doc. format. It works in word.
                              Twin power =
                              • G Doggett
                                • 477
                                Just had a reply back from Joe Ford at Castle stating that Bernie was incorrect in his reply to Klaus and that there is NO warranty on the Hydra 120 or 240 if using 4 or more Lipos as stated in the'fine print' of the instruction manual.
                                This is in spite of it being advertised as being suitable for up to 25 volts.
                                You have been warned !
                                Graham.
