Rx waterproof.. bag?
  • nosreme722
    • May 2011
    • 215
    where can i get one of those strechy rx waterproof things?
  • teach
    • 509
    I used to use non lubed condoms....kind of hard to find though
    • sundog
      Platinum Card Member
      • Feb 2009
      • 940
      Just get some large size toy balloons at the local Dollar store and cut the necks off. Seal it with a nylon zip tie.
      Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
      • sailr
        • 7128
        Find a small zip lock bag. After inserting the receiver, twist the open end very tightly around the wires and use two small zip ties. Works great for me. Much easier than a balloon.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • nosreme722
          • May 2011
          • 215
          Alright i'll try some of these, thanks.
          • ENCORE MAN
            • Jan 2010
            • 1096
            Much superior to ballons as you can see any moisture in the bag. I prefer the freezer bags as they appear to be a little thicker. BG
            • Jeff Wohlt
              • 2740
              Go to hobby lobby and get some smaller jewelry bags...they work well.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • sailr
                • 7128
                hard to find any freezer bags that are small enough. Do you have a source?
                Mini Cat Racing USA
                • ENCORE MAN
                  • Jan 2010
                  • 1096
                  No Jim, I just use the "small size" glad bags, cut them down, and twist them tight on the wires and double tie them as you do. BG
                  • m4a1usr
                    Fast Electric Addict
                    • 2036
                    I just use the cut off finger sections from latex gloves. Get the extra large size and all but the pinky finger are just the perfect size. Then seal the end with a zip tie around the wires. Never had a drop enter my Rx since using this method.
                    John
                    Change is the one Constant
                    • nosreme722
                      • May 2011
                      • 215
                      I used the figure of a plastic glove, see how that goes. Ill probably switch to a plastic bag soon b/c its a little bigger. Thanks guys
                      • Boaterguy
                        • 1779
                        latex gloves, larger ones can fit your ESC too if you cut a finger for the wires on the other side, pretty much a flexible radio box.
                        Non lubed condoms, balloons, or really anything latex or rubber and stretchy. You don't have to cut the neck off, I have squeezed very large receivers through, although you may need two people to do it.
                        • bigwaveohs
                          • 606
                          or this...
                          I let the dogs out...
