Is that your jewelry store? VERY NICE!!
WOW..............new website format!!
Good stuff. Like the improvements. Seems a little faster too. Hope the management tools are a little better for ya. =)
I'll have more feedback once I have a chance to make a few posts...FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Auto restore saves every 30 seconds. If you happen to have a crash, and its saved, when you go back to repost, you will see a restore auto-saved content. But its only there for a limited time.Steven Vaccaro
test 1 test 2 test 3
You will also find tables are now available for use.
Neu Motor Chart Model RPM/Volt Shaft Size Weight SM/F Length (in) Rm (Ohms) Io@10v 1506/1D 9500 5mm 6.0/6.35 1.8 0.0015 9.0 1506/1.5D 6800 5mm 6.0/6.35 1.8 0.0025 5.0 1506/1Y 5500 5mm 6.0/6.35 1.8 0.003 3.2 1506/2D 5200 5mm 6.0/6.35 1.8 0.004 3.0 1506/3D 3400 5mm 6.0/6.35 1.8 0.008 2.0 1506/3Y 1700 5mm 6.0/6.35 1.8 0.029 1.2 1509/1D 6700 5mm 7.48/7.94 2.1 0.002 6.0 1509/1.5D 4500 5mm 7.48/7.94 2.1 0.004 3.8 1509/1Y 3600 5mm 7.48/7.94 2.1 0.004 3.0 1509/2.5D 2700 5mm 7.48/7.94 2.1 0.0082 2.5 1509/1.5Y 2400 5mm 7.48/7.94 2.1 0.007 2.0 1509/2Y 1820 5mm 7.48/7.94 2.1 0.018 1.5 1512/1D 4875 5mm 9.88/10.23 2.4 0.002 6.0 1512/1.5D 3200 5mm 9.88/10.23 2.4 0.0035 3.0 1512/2D 2600 5mm 9.88/10.23 2.4 0.006 2.3 1512/2.5D 2000 5mm 9.88/10.23 2.4 1512/3D 1700 5mm 9.88/10.23 2.4 0.012 1.5 1512/1.5Y 1900 5mm 9.88/10.23 2.4 0.009 1.8 1512/2Y 1400 5mm 9.88/10.23 2.4 0.015 1.1 1515/1D 4100 5mm 12.00/12.70 2.7 0.0025 5.5 1515/1.5D 2700 5mm 12.00/12.70 2.7 0.004 4.5 1515/.5Y 4400 5mm 12.00/12.70 2.7 1515/1Y 2200 5mm 12.00/12.70 2.7 0.006 2.5 1515/2.5D 1700 5mm 12.00/12.70 2.7 0.01 2.3 1515/1.5Y 1500 5mm 12.00/12.70 2.7 0.011 1.7 1515/3D 1360 5mm 12.00/12.70 2.7 0.012 1.2 1515/2Y 1100 5mm 12.00/12.70 2.7 0.019 1.1 1521/1D 2900 5mm or 8mm 16.93 3.3 0.003 5.5 1521/1.5D 1860 5mm or 8mm 16.93 3.3 0.005 3.5 1521/1Y 1577 5mm or 8mm 16.93 3.3 0.008 2.2 1521/1.5Y 1050 5mm or 8mm 16.93 3.3 0.01 1.2 1521/2Y 780 5mm or 8mm 16.93 3.3 0.025 1.0 1527/1D 2160 5mm or 8mm 21.8 4 0.002 5.0 1527/1.5D 1500 5mm or 8mm 21.8 4 1527/.5Y 2500 5mm or 8mm 21.8 4 1527/1Y 1250 5mm or 8mm 21.5 4 1527/1.5Y 850 5mm or 8mm 21.8 4 2215 1Y 1440 8mm 24.8 3.3 2215 1.5Y 1020 8mm 24.8 3.3 2215 2Y 750 8mm 24.8 3.3 2230 1Y 725 8mm 48 4.7 2230 1.5Y 485 8mm 48 4.7 All 15 series motors have 12 slot stators and 4 poles rotors Steven Vaccaro
That table is at the bottom of this page.
http://www.offshoreelectrics.com/conversion.htm
Not sure how the table was done back when it was posted.Steven Vaccaro
