Traxxas Marine Motor
  • pribco
    • Feb 2011
    • 122
    Does anyone know the rpm of thr Traxxas Marine 550 brushed motor using standard 9.6 v battery.--this is motor used in Villan EX.
    I got one of these today and it doesn't "sound" as fast as the similar Aquacraft motor.
    If you step on my tail, you had best make plans to deal with my teeth!!!
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    They're designed to operate on 14.4 volts.
    • pribco
      • Feb 2011
      • 122
      Guess that means I am getting a little more than half speed--poop!
      • Make-a-Wake
        FE Rules!
        • 6057
        They are right in the 1700-1800kv range.
        • pribco
          • Feb 2011
          • 122
          Make--don't know what that means!!
          • Alexgar
            • Aug 2009
            • 3701
            Kv is rpm per 1 volt
            • Alexgar
              • Aug 2009
              • 3701
              Your looking at about 17000 rpm
              • pribco
                • Feb 2011
                • 122
                Algar-if I read you right, it would be 17k if I use tye higher voltage-but only about 10k with 9.6 battery--
                Guess I will put motor away until I build a tugboat--postage for returning is just not worth it.
                • Boaterguy
                  • 1779
                  with a 9.6V battery you will be getting 17000 rpm, as alexgar allready stated
                  to measure rpm you take KV (rpm per volt) * the number of volts, for you, it would be 1700*9.6 = approx 17000
                  • pribco
                    • Feb 2011
                    • 122
                    Thanks Boaterguy--that's not to bad.
                    Any idea what rpm the Aquacraft 550 puts out??
                    • ENCORE MAN
                      • Jan 2010
                      • 1096
                      The Aquacraft motor is a 27 turn fairly generic motor, makes about 100 watts of power and costs $13. You could consider a HPI SATURN 20 turn motor from Tower for $ 20. This motor is fan cooled and produces about 140 watts at 7.2 volts=a significant improvement and still very dependable. Make sure your esc will handle a 20 turn motor. BG
                      • pribco
                        • Feb 2011
                        • 122
                        encore-how do I translate what you said into rpm??
                        • Boaterguy
                          • 1779
                          you need to know the KV of the motor, there are ways of figuring it out otherwse, I don't know how.
                          • pribco
                            • Feb 2011
                            • 122
                            edite-mailed aquacraft-we will see what they say if a miracle happens and I get a reply.
                            I am assumong that if I use an escape rated for a 27 turn motor with a 20 turn motor the esc ill burn up. Is that the problem??
                            As per Traxxas-battery is actually 7.2 v--so I would only get 12000 rpm--not good.
                            • pribco
                              • Feb 2011
                              • 122
                              Encoreman--looked at Duratrax esc for the HPI motor you recommended--tech notes say motor must have 2 .luv capacitors installed (whatever that means.
                              Question is--is the HPI motor so equiped???
