Twin mono with non counter rotating prop?
  • JCAustralia
    • Jul 2008
    • 363
    Hi guys
    I have couple of cool Etti 1/8 strut that I would like to use to build a twin mono (25-27 inches range).
    My question is whether that would work with the prop rotating in the same direction?
    I have read that there are likely issues with Catamaran because the prop are too far apart. But what about with a mono with the props pretty close? Anybody done that?
    Counter rotating prop is not really an option for me at this stage as I have already bought the flex cable and counter rotating props of that size are very limited.......
    I'm not a racer and the project is just for fun boating with my mates.......
    Thanks
    JC
  • JCAustralia
    • Jul 2008
    • 363
    Common guys any opinions on the subject?
    I have those hardware that are screaming to be on a twin mono like this one
    http://www.hobbyking.com/hobbyking/s...dProduct=16516
    Thanks
    JC
    • siberianhusky
      • Dec 2009
      • 2206
      How do you plan on cramming all that stuff including batteries into a boat just a bit over 6 inches wide and still get the CG right?
      Would be cheaper and run better on a single motor.
      • Rumdog
        • 6667
        There is absolutely NO problem running twins in a catamaran.
        I'd think props spinning the same direction in a mono would cause some handling issues.
        • drwayne
          • 3012
          ditto.
          make sure your course rotates in a clockwise direction.....
          prop steer !
          • G-UNIT
            • 971
            Did anyone even thing about torque role with x2 props going in the same directions?
            just thinking from what I read on this site
            • Boaterguy
              • 1779
              two props pushing would create a semi- solid base, and torque roll shouldnt be a problem.
              no rudder would be needed if you were running in a circle.
              • Rumdog
                • 6667
                I hope you're kidding.
                • Boaterguy
                  • 1779
                  which part?
                  I don't think the torque roll would be as bad as you would imagine.
                  • drwayne
                    • 3012
                    I want 2 Oz of whatever you're on....
                    "No torque roll.. creates a semi-solid base ..". you're quoting extracts from setiup sheets for CR props .... a mono will yaw drastically..
                    No rudder .. seriously ?
                    A long rudder may be the only solution to prop steer and yaw ....
                    You can PM re postal for those 2 Oz.
                    W
                    • dasboata
                      • Dec 2010
                      • 3972
                      I built a twin gas 56" mono the only problem was a little hopping in the turns other then that no problems there was a vid of it on http://www.oneillbrothers.com/
                      • drwayne
                        • 3012
                        @dasboata.
                        Yes, larger hulls display less yaw...
                        Due to increased cantilever mass ( the weight spread from side2side compared total mass)
                        The application here is to a 25ish" hull.
                        Id build it, and budget for a rev cable, and prop for 'ron.
                        W
                        • JCAustralia
                          • Jul 2008
                          • 363
                          Now I'm having second thoughts about the twin mono project.....
                          I remember there was a guy who did a twin Supervee 27 thread about 2-3 years ago on OSE but I can't find it anymore....... Anybody know how to look for it?
                          • drwayne
                            • 3012
                            Try JesseJ .. that dude twins everything ...
                            W
                            • Boaterguy
                              • 1779
                              W
                              you don't need a rudder because you would be turning constantly with all that yaw.
                              2oz of paint thinner, lead fumes, and whatever that stuff was on the floor coming right up
