Converting Nitro to electric?
  • volcanix
    • Jun 2011
    • 3
    Hey all
    im thinking of converting my nitro tunnel hull cat to electric as the motor is stuffed, its an abc plastic hull that weighs around 1kg(give or take a few grams) and its dimensions are 290mm wide and 1090mm Long.(heres a link to what it is https://www.rcplanet.com/Kyosho_Lamb.../kyo41461b.htm )
    What would you guys recommend for a brushless set up in terms of motors, Kv, Esc's and props?. i would like around the 80-100kmph mark out of it, as i reckon this hull can take it easily(and be be stable), its currently running an inboard outdrive system , which i think i would like to keep for ease of use/ budgetary constraints.
    Please as i miss running this boat alot
    thanks
  • Make-a-Wake
    FE Rules!
    • 6057
    Leopard 5692 or a Castle 1717 would be my suggestion.
    • volcanix
      • Jun 2011
      • 3
      hrm the castle doesnt seem to be built any more, but what esc/ prop should i pair your other suggestion with?
