williams twin 1717 floor mount
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1097
    I finally received my mount and 1717 jackets today, the mount wont fit between rails (that I didn't want) so they'll be removed to make room for this baby, I'm very pleased with this mount, maybe I've been spending too much time in the shed, this thing is sexy!! Well done jim.
    "Gimmy Toyz for FUN"
  • Fast One
    • 220
    That looks way to cool!!!
    What are you puting all that power into? I think that mount would be great for a twin rigger!
    • millzee
      Ozzie Bloke
      • Nov 2010
      • 1097
      thats going into a Aeromarine sprintcat 80/90 with t180's on 6s2p, should be fun
      • scoota
        FE DOWN UNDER
        • Dec 2008
        • 439
        Love the mount , nice & neat , good stuff millzee you should start a thread in the build section mate ?
        UL1- 1515 castle/neu / 240 swordfish
        SV27- with UL1 running gear
        33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
        • millzee
          Ozzie Bloke
          • Nov 2010
          • 1097
          I'll finish off the mean machine first, then I start a thread on the big pussy.
          • Boaterguy
            • 1779
            you might want to run two seperate cooling systems, or a small ziploc container of ice to cool the water between motors.
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1097
              I've been having a bit of a play around with the cat now that I've removed the rails and I have a couple of questions.
              *What's the performance difference between having 1 rudder mounted in the center (just behind)of the prop's or if I was to run the props as close as I can and use a 2 rudder system, one on each side of the prop's?
              *With the speedmaster large struts, they didn't come with any type bushing, can some one either link me to a thread on how to set it up or fill me in? I'm still tossing up weather to run a 1/4" stuffing tube with 7/32" bushings or to run the 9/32" with teflon.
              *With a cat, is it best to have a long drive shaft with less bend or a shorter shaft?
              any advice or links would be appreciated.
              Thanks
              Danny
