1518 measurement?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    1518 measurement?
    Measurement on a 1518 from the front of the can to the lip of the wire grommet. Basically the spread for a motor mount. The distance in mm from farthest point on the can that a clamp will seat and the front of the motor.
    The 1520 is 78mm, so assuming the 1520 is 74.5mm from the grommet to the nose, but want to be sure.
  • Alexgar
    • Aug 2009
    • 3701
    here you go Ben
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Originally posted by Alexgar View Post
      That's what I'm going by, but looking for an actual measurement of the distance from the wire grommet to the front of the can to be certain it will fit in a mount. =)
      • carlcisneros
        • Jan 2010
        • 1237
        you need the 1518 or the 1520 Ben?
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          1518, if you have a 1520 mount there (which you should) See if the 1518 will fit in it.
          Didn't know you had a 1518.
          • carlcisneros
            • Jan 2010
            • 1237
            Ben, I was sort of confused here.
            I do not have a 1518 I do have the 1520's and a 1515.
            My 1520 has the water jacket for the 1518 on it and mounted in one of your mounts.
            fits perfect.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              fits perfect.
              Oh, cool. That I need to know too for certain. I have a 1518 cooling can coming for the 1520 in the Genesis build.
              Fun stuff for sure.
              Now... I need to find out if the 1518 fits using a 1515 cooling can. I think it does, but just barely.
              • carlcisneros
                • Jan 2010
                • 1237
                I have the 1518 cooling can mounted with ONE (1) grove showing at the front end of the motor
                so that the rear clamp can be mounted to the motor.
                naturally you have to put the mounting ring on first then install the cooling can. :-)
                • carlcisneros
                  • Jan 2010
                  • 1237
                  Ben, did some measurements this morning and the can on both of the motors are 2 5/16" long.
