How do you remove MHZ Mystic Drives ?
  • arrowskartax9
    • 130
    Ok. I have water coming from behind one of the drives bolted to the rear of my MHZ Mystic. It is screwed on from the inside of the hull. What are the screws screwed into. Nuts or a plate? And how do i seal it up?
    Chris.
  • iamandrew
    • 574
    isnt this exactly the same as your other post?
    • arrowskartax9
      • 130
      Yes it is Andrew but, I need to find out if the bolts thru the hull go into nuts or into a plate inside the mock gearbox on the outside of the hull.
      Then i can remove it and seal it up.
      I got the boat as a rtr so im not sure if what i want to do is correct.
      Thanks,
      Chris.
      • Anbjorn
        • Apr 2009
        • 248
        Hi,
        The 3 bolts go thru the hull and into the "gearbox" part of the drive.
        See attached pictures. Not the best pictures but it will give you an idea.
        Anbjørn
        • arrowskartax9
          • 130
          Thank you.
