Df33 cyber storm set up
  • jfrank71
    • 515
    Trying to get my df33 running top speed. Best i Can do is 45 mph on x645 with 2s + 3s in series for 5s1p. Also, running neu 1515 1.5y 1500kv hull looks good in the water flys level when airborne cog appears to be right. Its close to 30%. Will it make a difference running 5s2p? Also, how do you wire for that? Do you have to make parallel adapters? Any help heRe would be much appreciated. Thanks, frank
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Run 6s with an X447/3. That'll wake it up to around 60mph with cool temps. Play with COG and it'll handle good and you'll be happy.
    • oscarel
      • Dec 2009
      • 2373
      Hey Frank, here are 2 parallel connectors I use. What ESC are you using?
      • Boaterguy
        • 1779
        Parallel will not make it faster, it will give more mAh, longer runtimes.
        Have you tried playing with the prop height? angle?
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 439
          You might get in to the low 50s with the 1515 , i have the same hull & started with a 1515 , its a tad small for that hull if you want better speeds , im running a leopard 4082 1500kv on 6s , with speeds in the high 50s , low 60s with no heat issues .
          UL1- 1515 castle/neu / 240 swordfish
          SV27- with UL1 running gear
          33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
          • Alexgar
            • Aug 2009
            • 3701
            I was thinking a little small also I use that motor in a df29 1520 or 1717 would rock that hull
            • jfrank71
              • 515
              Thanks for the input guys. That's what I was thinking. I'm on the hunt for a 4082 now. Will make due until then. You the 1717 will work as well as the 4082? See some of those for sale but will have to find water jacket.
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                www.kershawdesigns.com has the 4082 your looking for. OSE is out of stock on them. Do you want to sell your Neu 1515?
                • jfrank71
                  • 515
                  Kershaw is out of stock on the 1500kv just checked.
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    Get the 1600kv. It's the same, just a different lable. I have one in my DF 33 and love it. If you sell me your Neu, you can offset the cost of the Leopard.
                    • jfrank71
                      • 515
                      I saw the 1600 kv listed but it shows out of stock. I think the 4082 might work better than the 1717.
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3416
                        Didn't know kershaw was out of stock. Sorry for misleading you. www.southriverrcboats.com sells them, but, they too are out of stock. You can post a WTB for one. The 1717 runs nice in these hulls too. I think Johnson22456 has one for sale in the swap shop. Run it with an X447/3 or an X450.
                        • jfrank71
                          • 515
                          Thanks for your help. What about motor location. Front or rear of the boat?
                          • photohoward1
                            • 1781
                            To Low a KV for 5s. I run it with a 2100 kv motor. 1515/1y and it screams on a 45/55 abc. close to sixty. 4s2p 6600mah.
                            This is a great 4s boat. Even running it on a UL1 with a 45/55 you should see 45.
                            Great LSO.
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3416
                              I place 2 batteries laying down next to each other against the transom and put the motor 1/2" to 1" in front of them. You just have lay out different locations with components to get the COG right. Batteries will be the biggest player in adjusting this. Make it so you can fudge them fore and aft.
