1/4" to 3/16" strut conversion
  • BHChieftain
    Fast Electric Addict
    • 2051
    Hi,
    I have an existing 1/4" strut that I'm trying to convert to allow use with a 3/16" prop shaft. Is there a bearing that has a 1/4" OD and a 3/16" ID?
    I tried a standard speedmaster 3/16" strut but the OD is too small...
    Chief
  • JimClark
    • 5913
    Octura makes a lead teflon bearing in that size Steve list's them
    Billy Graham
    • RayR
      @SiestaKey.calm
      • 1591
      Just buy a 1/4" shaft with a prop shaft step down to 3/16" prop. Sold all over the web, including this site. But usually out of stock here.
      http://www.offshoreelectrics.com/pro...od=hug-b8666sp
      We don't call it "Out Of Stock Electrics" for nothing.
      • BHChieftain
        • 2051
        I have a "non-standard" config on this boat where the shaft and flexdrive is 1/4", but my motor shaft is 5mm, and I can't readily find a 5mm to 1/4" coupler (they are typically 6mm to 1/4).
        So I want to run a "standard" 3/16 shaft and flexcable, and use that with a 5mm to 3/16 flexdrive flexhex coupler... provided there is a bushing that will step down the strut from 1/4 to 3/16...
        Other solution is to use the 1/4 shaft and cable (turned down to 3/16), but need to find a coupler that will work with a 5mm shaft.
        Chief
          Well what size is the strut? If it was designed for a 1/4" stub and you want to run a 3/16" cable, you might actually have 3/8" ID to deal with...
          If so, you can find bearings 3/8" to 3/16" for your strut.
          If not, just shim down with K&S tubing and use a Speedmaster type brass sleeve bearing.
          • BHChieftain
            • 2051
            Hi,
            The current strut is 1/4 inner diameter, but it does not appear to have a bushing in it. I like the idea of using K&S tubing to shim it... I have a new speedmaster 3/16 bearing, but the OD is too small for the 1/4 strut.
            Thanks!
            Chief
            • Boaterguy
              • 1779
              http://www.offshoreelectrics.com/pro...at=Flex+Cables
              get the 7/32 and 3/16 tubes, slide one inside the other, and slide that into your existing 1/4 strut. You will have to cross drill them, and possibly solder them to reduce all of those shafts sliding around.
              • BHChieftain
                • 2051
                Thanks! I'll give that a go,
                Chief
                • BHChieftain
                  • 2051
                  Thanks-- I'll try those as well
                  Chief
                  • 785boats
                    Wet Track Racing
                    • 3423
                    I'd be going to a local bearing supply shop & getting a couple of stainless steel ball race bearings to put in the strut. I did one a couple of years ago & it's still running without any play in it.
                    Cheers.
                    Paul.
                    • BHChieftain
                      • 2051
                      Found some 1/4 OD brass tubing at the hobby store and checked if it would fit. It is actually too big, so the strut must be metric-- it is 5.9mm according to the caliper which I think is an odd size...
                      Is there a teflon tubing size that might fit this?
                      Last resort will be to replace the strut.
                      Chief
                      • BHChieftain
                        • 2051
                        Ok, closer inspection of this strut reveals that there is some sort of inner sleeve that is just under 1/2 inch long inserted into the aft end of the strut. If I can figure out how to remove it, then I will be able to slide in a new 1/4" stuffing tube into the shaft and I'd be set.
                        I could either have it drilled out if I can find a machine shop, or I could try heat-- how long would I need to put the strut in the oven before trying to tap out that inner ring (I can get a long allen wrench down the other side to catch the lip)
                        Or instead of the oven, should I use my 140W solder gun to heat up the end?
                        Chief
