Originally posted by Boaterguy
View Post
Exceede rc Shark
Ugh. I am familiar with that type of drive shaft. It also exsists in this boat, which I own two of.Originally posted by martin View PostThese are strictly 2s max, One thing you might want to check on if your considering getting one. Certainly in the UK some spare parts seem to be out of stock a lot of the time especially drive shafts & once their out of stock it seems to be several months sometimes before they get them in again. One thing ive noticed their out of stock most is drive shafts, They use quite a strange shaft on this boat so would be more difficult to perhaps adapt another make shaft like you can on some other boats. As the drive shaft is 4mm solid apart from the last 1.5" or so at the motor end where the solid shaft has a small length of flex around 1.25"- 1.5" that goes into the coupling. Martin.
Might be the same maker. Those shafts end up breaking where the flex shaft is soldered into the solid shaft. Big failure point. Either order some extra shafts or figure out a substitute.
Keep us posted broOriginally posted by eric01 View PostBrushless55, I will let you know how things turn out. It should be here Monday or Tuesday. A friend of mine has an older Shockwave 26; it gave him all kinds of headaches (mostly because of the AM radio). I converted it to brushless for him and gave him the stock 2.4 gig radio that came with the MG. I thought we would both have more fun with similar boats, racing each other. Otherwise I get kinda bored running the MG competing with myself for a better top speed. It sometimes takes flight now, I don't think that hull needs to go any faster
thank youOriginally posted by Smoothops View Post
