anyone try one of these yethttp://cgi.ebay.com/ws/eBayISAPI.dll...m=110174211355
ebay esc
they also have a 200Amp for 215$ I did read good thing about ETTI in general
thats the same one I bought for my rigger the 125A 6-20, same here keep you guys informed of how it handles but have had several people tell me they are fantastic!
-Wayne
Stevo,
Are you running a 9XL Fiego in your SV? How you like it? I'm trying to get someone to answer me on what Fiego would be the fastest usable in a SV27. Any suggestions? I have the Hydra 120 and will be using 4600 NIMH's.
Thank you!!
ran it today with the etti speed control seemed to work real well, water was alittle rough managed to get 30 mph of of the boat which i wasnt happy with but given the conditions and batteries that i need to bring back to life, and i stuffed it into a wake and was able to get back to shore under its own power everything was fine
Did you have to reprogram it or does it work with pistol style radios?
Hi Steveo,Originally posted by steveo View Postno works with pistol grip just plug and play, real easy to adjust parameters and settings
I just purchased one these ESC's, l am having major problems trying program it for Lipo (cuttoff Voltage 6.0) - I using a spektrum pistrol grip.
Can you please tell me in very simple steps how to program this great ESC for Lipo.
Thank you in adavance !
BTW: I followed the supplied instruction sheet in which the beeps didn't seem to match up it all became very confusing.
you may of had the same trouble i had, when i picked my parameter with in the timming setting it would sound off in a different tone then go back to the begining of those parameter tones, what i found is that when you pick your parameter and it goes back to the begining just pull the trigger back and it will arm just like it does when you first turn on the controller,
i was able to change the timming of the motors this way, now if you want do a test and change your motor timming to the next parameter just to see if you got the hang of it and it save the change, then bump the throttle and see what it does, i know the controller would not turn the 6 pole sv27 very well in the 2 pole timming thats how in knew it did not change and i went into the settings again
i hope this helps i will be following this threadLast edited by steveo; 02-03-2008, 08:51 PM.
