Apache 24 upgrades?
  • mtnbiker94
    • May 2011
    • 62
    Apache 24 upgrades?
    I have a Proboat Apache 24 and I want to make it a little faster. Is there any cheap esc and motor I can throw in there from Hobbyking or something that'll work?
    Thanks Tim
  • Make-a-Wake
    FE Rules!
    • 6057
    Since you are asking for HK stuff specifically, this motor will really wake it up..........i have several and they are very good for the money.......they're vented on each end as well. Run it on 4s.
    http://www.hobbyking.com/hobbyking/s...idProduct=6526
    throw this esc in your order, real workhorse.
    http://www.hobbyking.com/hobbyking/s...idProduct=8946
    • mtnbiker94
      • May 2011
      • 62
      Hahaha i just figured Hobbyking would be the cheapest but im open to other options, lol. If i got that motor wouldn't i need a water cooler?
      • JackBlack26
        • May 2007
        • 904
        Don't get anything higher than that 1800 Hk motor or it will be too fast to be functional. Use the Shockwave BL motor coupler. Buy a cooing can from OSE. Have fun!! :)
        • mtnbiker94
          • May 2011
          • 62
          Okay thanks alot! The only other thing i was wondering about was how do you program those turnigy esc's?
          • JackBlack26
            • May 2007
            • 904
            With the program box. You can also do it with the transmitter but it's like reading morse code. Easier to just spend the few extra bucks for a programmer.
            • Make-a-Wake
              FE Rules!
              • 6057
              Yeah, that 1800 will make the boat friggin scream.................you may want to consider a little milder motor for 4s...............still will make it rock!
              http://www.hobbyking.com/hobbyking/s...idProduct=6528
              • mtnbiker94
                • May 2011
                • 62
                Yeah I don't want to put much money in it at all. So that motor would be perfect but the 120A esc seemed a little over kill for that boat. Anything a little smaller? I mean all I'd probably run in it would be at max, probably 3s. So I don't really need anything special
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Its the best bang for the buck out there...............the 60a version is 10 bucks more, get the 120 and give yourself some breathing room and let it run nice and cool.
                  • tunnelvision
                    • 819
                    Something along a lines of a 2860 2500kv to 3000kv on 3s would work nicely too. I had a similar motor to this one in mine and it went really well, high 20s to mid 30s depending on the prop. Mine was heavy as I reinforced it with a couple layers of glass. installed a flex shaft and new rudder. Spent a nice chunk to make it go though. Get the 120a seaking/turnigy too. You can always use them, they are great escs for the money.
                    Here is the link for the motor, sold out now but you can find similar ones on ebay.
                    If you want some more speed out of the box on the apache use a 40 or 42mm carbon fiber prop from OSE. Much, much faster but you have to watch the temps. Here is my old one box stock with a 5000mah NIMH duratrax, 42mm prop.
                    With a 2s lipo it would move a bit better too.
                    Go Fast...Turn Right...
