df 29 questions
  • driftah
    • 759
    df 29 questions
    i have a df29 with a seaking 180 esc and a 7xl motor in it.I have been messing with props like x445,42x55 and today an x447....wow goes like a bullit on the x447 but started to swell my 50c lipos,maybe too much amp draw and yes I maybe should have a lower kv motor lol.So what motor/prop selection should I use to not risk swelling and still be fairly quick...? I also have a neu/castle 2200kv that I can throw in it but want others info please......
  • lectriglide
    • 540
    I was running a 9xl (1853kv) with an X642 on 4s 5000 40c and gpsed at 46.1. Don't remember the exact amp draw (thinking peaks at 125 or so) but I'll check when I get home tonight.
    I put an 8xl in it but haven't run it long enough to get any readings yet due to a lost prop shaft (broke solder joint).
    IMO 7xl (2382 kv) is too much on 4s especially with that big a prop. I bet your amp draw is really high. Big prop, lower kv motor (1800 - 2000) - smaller prop, motor kv (2000 - 2200).
    • 785boats
      Wet Track Racing
      • 3423
      A sweet prop on a 7Xl in that size hull is an X437/3 blade. Lets the motor rev & doesn't draw so many amps. If the boat is really aired out a Grim racer 40mmx52mm also works well.
      Paul.
        • 7512
        You didn't mention what voltage you are running,
        If its 4S then that explains the problem
        • 785boats
          Wet Track Racing
          • 3423
          Good point Doby.
          I was assuming driftah was running 4s.
          Is that right driftah?
          The props I mentioned are for 4s as that's what I ran in mine.
          Cheers.
          Paul.
          • FastVee
            • 659
            Maybe this will help, I did some experiments last year with my 29.
            x440 was really good prop on 4 and 5s, 6s snapped the 3/16 flex on 4s the batt temps were fine(40C 5000mAh)
            x442 would propably be good also.
            Sold the boat last summer to a friend and it still goes like a missle!
            www.youtube.com/rangerpate
            • driftah
              • 759
              it was on 4s sorry
              • ksm2001
                • 397
                I run my DF29 using a 8xl on 4s, prop is a m445, current draw is 139 amps with a speed of 57 mph. I don't remember the temp readings but I can run it for 4 min on this setup with no problems.
                This hull is a blast to run
                Ken
                DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
