Bellows To Hull quastion...
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Simple quastion:
    What would be the best product to install bellows/rubber boots to the hull?
    I know some use silicone but is there something better?
    A to B
    Check picture please.
    Thank You
    Robert
    Canada
  • ron1950
    • 3082
    i used a little 5 min epoxy on mine then some silicone ..either is good for me...just remember tape doesent stick to anything siliconed
    • marko500
      • 862
      I usually epoxy a piece of brass tube into the hull with a 1/4" or so sticking out. Then slide the bellows over the tube. Secure with a zip tie or a piece of silicone line stretched over it to act as a clamp. You could also glue it on but you'll destroy the boot if you ever want to remove it.
      Mark
      • JimClark
        • 5913
        some don't even use them
        Billy Graham
        • siberianhusky
          • Dec 2009
          • 2206
          Goop or shoe goo.
          • kookie_guy
            • 900
            CA glue. Install the boot into the hole, put a drop in one spot, and the CA will flow around the complete perimeter giving a solid seal.
            • dana
              • Mar 2010
              • 3660
              Mark
              i really like this idea. makes me want to rip all my boots out and redo them lol
              • blizard05
                • Jun 2007
                • 585
                Mark
                I do the same thing,but use a peice of plastic from a bic pen
                America home of the free, thanks to the brave [/url]
                • sailr
                  • Nov 2007
                  • 7128
                  This is the same way I do it but I leave aout 3/8" sticking out. That gives you a more secure surface to zip tie your boot to. I never glue them. Some glues will deteriorate the rubber boat over time.
                  Mark
                  Mini Cat Racing USA
                  www.minicatracingusa.com
                  • Darin Jordan
                    • 9446
                    If you are working on the Stiletto and are replacing the bellows, I'd listen to the guys on the brass tubing, making sure to run it all the way through and gluing it on both the battery tray side and the radio side. I think the way the factory installs the bellows on this boat is part of the reason it gets water inside it from time to time when overturned.
                    I do the same at the back of the boat, even so far as to add two more holes back there and running the wires for the ESC/Motor connection out individual holes so they can be better sealed.
                    Darin E. Jordan - Renton, WA
                    • LiPo Power
                      • 3678
                      Great help, thank You!
                      Canada
