Leopard 36mm Cooler ID??
    Could someone please measure tthe ID of the Leopard cooler for 36mm motor for me??
    That is without the O-ring inserted.
    I need to know if it is 36.5mm or larger, smaller???
    Thank you!!
    One of mine measures 36.45 mm just outside of the O-ring. I do not know if it is different immediately inside of the 0-ring as I did not take one out.
      That will be sufficient to fit onto my UL-1 motor then. Thank you so much!
        Actually, maybe I should ask yuou to measure the outside can of a 36mm motor?
        If you can please, thanks!?
          They aren't quite round, but mine average 36.09 mm on the same mic that I measured the cooling can with.
            Thanks for the input.
            Out of 5 Feigao thin black water jackets I have, I was able to get one one my UL-1 motor.
            I did have to put a 1/32" champfer on the motor with my lathe though.
            I was going to buy a Leopard jacket to try if this one didn't work.
            That last dimension is great, thanks. If O have a problem with this black cooler, I will grab a leopard.
            Cheers!
