hydra 120 and motor question
  • steveo
    • 1454
    looking to buy a hydra will the speedo run both my fegiao and sv27 motor without the aid of a computer to adjust timming if need be.
  • chunt92
    • 48
    Im notsure about the fieago but the stock motor ran to good on4s lipo i burned it up monday am. not sure if i had the timing to high or what. it was set 4 race not sure how high that was but i guess it should have been in normal mode.
      • 7990
      Guys - do not set your ESC timing to the highest setting! With most motors it makes no speed difference, but it does heat things up real fast. For 95% of all running with a Castle ESC, use the lowest, #1 setting only. As a frame of reference - the fastest 4S boat in the world ran a Castle/Neu combination, and he used the #1 setting to make a pass at 114 mph.
      • chunt92
        • 48
        Set in the below normal mode?
          • 7990
          Yes, #1 = low timing = SAW record. A lot depends on the motor design, but there is no reason to use more than #2 - and you are usually better off with #1. Motor timing is a tuning aid, not a magic recipe for maximum speed. Is one mph - if that - worth burning up a $200 ESC?
          • chunt92
            • 48
            true but i wish some one would have told me that befor i burned up my stock motor. i just got a 36-50- 2300 ammo motor and a hydra 120 in a super vee i would like a prop recomendation?
            • Diegoboy
              Administrator
              • Mar 2007
              • 7247
              X642 is what I used
              • chunt92
                • 48
                I had a m447 on the stock. is/was that to big?
