PAINT: Spray guns, tips, links to supplies...
  • detox
    • 2310
    I used Summitracing's single stage urethane paint with matching primer surfacer. Primer is very thick and needs extra thinning. Very strong bond using these two together
    Harber freight HVLP spray gun will work. Practice, adjust gun, practice, adjust gun, then spray.
    • egneg
      • 4664
      Would I need anything special for a compressor to run a HVLP gun? I guess it would need a big reservoir tank.
      That is a good looking gun but is there anything similar by a worldwide company, the Sharpe only seems to be available in the states and once I factor in shipping, tax and postal costs this end it looks like about $240 to my door, if I can get something similar from a bigger brand locally it would work out less than half price. In that sort of price range I could get a Fiac Merlin or UPOL maximum mini, anyone used either of these?
      edit: ouch I just found that HVLP guns run on turbines not compressors, the cheapest used turbine on ebay is $400 as opposed to $160 for a compressor, and I'm guessing you cant run air tools or pump your tires up with a turbine so it lacks the versatility and cost sharing of a compressor. Is HVLP definitely the way to go? It would take me a very long time if ever to break even with rattle cans at that price.
      Look for something like this over there. I use this gun with good results.
      http://www.harborfreight.com/hvlp-de...gun-46719.html
      IMPBA 20481S D-12
      • egneg
        • 4664
        Here is a link to help you set up a paint gun. The first link is part one and the second link is part two.
        Bring powerful images to life in seconds, Airbrush has all the tools you need to create everything you can imagine.
        IMPBA 20481S D-12
        • detox
          • 2310
          This is the one I use. I spray primer and color coat. It can be adjusted for small touch up. Watch the video.
          http://www.harborfreight.com/high-vo...gun-66222.html
            • 9479
            how big of a compressor do you need with this gun?
            • 6sHyper
              <<<Surfs up!
              • 597
              NO, you do not need a turbine to run an hvlp gun, you got it wrong your thinking of an hvlp air system, which is totally unnessasary. A regular compressor will run an HVLP gun , your "suppose" to have the bigger air lines and fittings but its not gonna stop the gun from working if you dont either.
              Brushless, the size of the compressor you need is all dependant on how big of a job you plan on spraying? If for example your just spraying a 32" boat a little "pancake" style compressor would get the job done for you, basically any compressor would as long as you had like a 20 gallon reservoir that would be enough air to get a coat on then it could recover while your waiting between coats. To do a complete car the bare minimum would be a 60 gallon reservoir and pump capable of bare minimum 10.3 cfm@90psi.
              • 6sHyper
                <<<Surfs up!
                • 597
                these are a great buy, comes with 3 tips, so its good for primer and base and clear. All metal construction, so as long as you clean it properly it will last forever. (cheaper harbour freight guns have teflon oand plastic internal seals that wear out)
                http://cgi.ebay.com/ebaymotors/DeVIL...motiveQ5fTools
                keep an eye out for used or no reserve $0.99 starts too, deals are there
                http://cgi.ebay.com/ebaymotors/DeVil...motiveQ5fTools
                These are really cheap, but i would probably buy the first link i posted with 3 tips:
                http://cgi.ebay.com/ebaymotors/3-Dev...motiveQ5fTools
                this gun is worth $500+ heck i'm going to bid on it!
                http://cgi.ebay.com/ebaymotors/Devil...motiveQ5fTools
                this is an awesome gun!:
                And theres tons more...........
                • detox
                  • 2310
                  Everyone should have an air compressor around their home. Buy the highest SCFM rated, 110 volt air compressor you can afford. When I sprayed my Whiplash I used a small Craftsman 1.5 horse 2 gallon compressor (it was barely enough and ran constant).
                  • egneg
                    • 4664
                    I have a small oil lubed Craftsman that my wife got at a garage sale (needed a gasket) and I added a 5 gallon tank from another garage sale compressor. Total investment is under $25.00. This is more than adequate to supply my detail gun.
                    IMPBA 20481S D-12
                    • Insaniac
                      • 425
                      What sort of filters and water traps do you need in the air line with these touch-up guns from Harbor Freight?
                      Support US hobby suppliers
                      • detox
                        • 2310
                        The plastic disposable air line filters work great. I have seen them at the Harborfreight stores, but not their online store.
                        • G1ST
                          • Dec 2010
                          • 348
                          I ended up buying spray cans online http://automotivetouchup.com/spray_paint.asp
                          I got their basecoat clearcoat system. I got a couple of runs in the clear (happened really fast) but I am pleased with the results.
