I have a b230 and b235 props here for it but it looks like it will be too much,If I get the 4074 will it spin the props I have or will I have to grab a few smaller ones?I see that the 180a esc is out of stock
Noobie needs some help with setup
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Thanks make a wake!! i did find it on OSE in a set with a 4074 motor,I ordered it so if I feel its not enough I can always upgrade to the 4082 motor,I'll post pics as I build the boat!! Thanks again for all the help guys
If you got the 1400kv 4074 for 6s, try an m445.................should rock!
http://www.offshoreelectrics.com/pro...?prod=oct-m445
If the props you mentioned are Prather 230, 235's they are too big.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
The 2000kv is a 4s motor..............you are aware right?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Ask if he will substitute the 1400kv for it.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
See if he'll swap the m442 for an m445 too............................just my opinion.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Its all rigged and ready to go,test run is set for Saturday,I'll post pics and maybe a video then,Thanks again guys!!!
Well Guys I ran it this past weekend and all I can say is WOW what a difference from nitro to electric!! I was very surprised by the speed it had with no setup time,just the stuff you guys recommended me to get.Hers a few videos to show ya'shttp://www.youtube.com/watch?v=yni9P65-9zE
Not too bad at all! Depending on what angle the motor is on now, I would either add a touch of negative, or shift some weight forward if you can. That should keep the nose down but still let the hull run loose without risk of a blowover.Light travels faster than sound, so people may appear to be bright until you hear them speak.
