LiPo Construction
    • 7512
    LiPo Construction
    Anyone know of any articles on how to properly build LiPo packs ??
  • sjslhill
    • 1563
    try rcgroups, maybe there is an article there with images. Myself, I use a heat sink on the tabs when soldering. It's just a small clip with smooth edges so the tabs are not damaged. 2S is simply soldering negative to positive and using the other + and - for the leads. 3S is the same - + - + - + The positive electrode is not nickel unless you buy cells that have it added on.
    I hope this helps some.
    thanks,
    Steve
    • RCprince
      • Jul 2007
      • 1684
      http://home.comcast.net/~truerc/tuto..._assembley.htm http://www.dream-models.com/eco/LipoPack.html
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • SJFE
        • 4867
        That link it really helpfull. I wonder how you solder in the taps????
