throttle question
looks like you are ready for a on the water test then. Or put a air prop on so you have a load on the motor.Originally posted by dasboata View PostI played with EPA and trim it is much better but hard to tell if it is proportional and the trigger matches the RPM as I don't want to over REV it,, thanks for waking up my brain Chris
Leave a comment:
I played with EPA and trim it is much better but hard to tell if it is proportional and the trigger matches the RPM as I don't want to over REV it,, thanks for waking up my brain ChrisOriginally posted by TheShaughnessy View Posttry recalibrating and messing with the epa on your throttle if it is adjustable. I've had to set a the epa to 0 for negative throttle on a tx once.
Leave a comment:
Leave a comment:
bit of a burn looks like there. not good. :-(
sounds like you will have to completely reprogram the ESC from scratch.
jmo
Leave a comment:
throttle question
I had some problems at the lake yesterday I lost my settings on the ESC and when I pluged in the Lipos they were at full bore,, I quickly disconnected them and in the process touched the wires together for a split second my ESC has lost it's program settings, But any way I got the boat running and I have to pull back the trigger half way to get the boat to move, and then it is at 1/2 speed at least what do you think I screwed something up ? thanks chrisAttached FilesTags: None
Leave a comment:
