Imex riva classic speed boat
  • Joe007
    Joe
    • 124
    Hey guys I have this riva speed boat that is 33 inches long... The props are plastic and are always breaking... It has a twelve and half inch solid steel shaft that is 4mm thick... the prop is about a 35mm three blade with a grub (set) screw to hold it on the shaft... Any one know where I can get a brass prop for it?
    Joe
  • Alexgar
    • Aug 2009
    • 3522
    Can you add a pic I had a abc hobby boat with 4 mm shaft and it had a drive dog and ring that had set screws and you could buy a 3/16 prop and put a piece of 3/16 brass tubing as a spacer down to 4mm
    • Joe007
      Joe
      • 124
      Here are two pictures of the shaft... The first one is the end of the driveshaft with the notch for the set screw...
      Joe
      • Joe007
        Joe
        • 124
        I was also thinking of buying a brass rod and threaded for a prop...
        Joe...
        • Alexgar
          • Aug 2009
          • 3522
          Pic of the prop also please
