Hi guys
(note to admins im just rebuilding this rigger and posting a few photos to show how i did it as i know lots of people out there got one of these and this is what i did so if you ant to move this post or deleete it feel free)
I just want to let people know what they are in for
cheers
bob
ok after a few weeks now of running my R2 hobbies rigger i am starting to see water in the hull and quite frankly i am really unhappy with a few things in the boat (sponson tube positions, people giving outrageous statements of what speed their boat has done, lack of room and flimsy build quality.)
essentially i am going to run a leopard 4074 2150 KV motor turnigy 180 esc and run it on 14 V if it kills me or i spend way too much it will be a learning experience for myself.
to start with i have here a pic of the motors i have the small feiago and the swordfish motor have been tested but they both really lack the punch that i need.
i only ran the blue swordfish once and my coupler that was supplied with the kit busted a pooper valve and refused to grab the cable. first problem, then the second problem was noticed water was inside the rear sponsons so i had a leak
this is what i have done this morning first taken of the rear sponsons and please note i have not used any cutting tool at all to do this so this is how POOR the glue they have used is, i just used my fingers to push the pieces apart. the glue cracks easily and pulls apart.
i decided to pull the sides of the tub off this was easily done by using a thin wedge rudder and gently pushing down like this
now after all this has been done the hull looks like this, very workable and i can surly force in my nice big leopard motor where i want it, please note i have ripped out the motor mount and replaced it with a water cooled one funnily enough the ply for my engine mount had already started to delaminate due to water getting to it.
next job to do was to get the sponson tube holders into a lower position so a battery can fit up front and adjust the position that the front one is at so it can be a bit more forward of its current location to fit a larger battery as the current batteries i have are 145 mm long (Zippy 40c series 5000 mah 2 cell). so i have removed the aluminium tubes and will glue them in to place after i have cleaned up the central tub skeleton a bit
cheers guys i hope you like this one
cheers
bob
