Charging AA batteries
  • Smoothops
    It is never fast enough..
    • 142
    Lots of rc toys= lots of batteries, I would like to charge them with my li-po charger but wondering what settings to use? My main batteries are 2700 mah.
  • jingalls007
    • 1172
    It depends on the type of battery. Most likey they are NiCad or NiMh. Your charger ABSOLUTELY has to be compatible with the Chemistry of the battery you want to charge. What charger do you use?
    • Smoothops
      • 142
      My charger and i believe they are all NiMh http://www.hobbypartz.com/75p-t6-multi-charger.html
      • jingalls007
        • 1172
        The T6 is compatible with NiMh. Do you have the adapter to charge them? If there's a requirement to manually enter in your milliamps, in this case 2700, make sure to do that as well. You should be good to go!
        • Smoothops
          • 142
          yes
          That is my question how many amps do i charge 2700 mah batteries
          • jingalls007
            • 1172
            look on the batteries. It should say 1a-3a. I charge my NiMh receiver pack at 2amps.
            • Smoothops
              • 142
              It only says Std. Charge 270 mAh 14 hours
              • jingalls007
                • 1172
                If you enter in the Milliamps does it chose your amp rating for you? I've always charged NiMh at between 1-3 amps. Who makes the cells? Do you have photos?
                • Smoothops
                  • 142
                  yo
                  Orion 2700, thanks for the help
                  • jingalls007
                    • 1172
                    You should be fine charging at 1a.
                    • Smoothops
                      • 142
                      Thanks ill just charge them all at 1 amp and will be safe?
                      • jingalls007
                        • 1172
                        You should be fine. I checked Orion's site for you but didn't find a specific amp rating for those batt's. Keep an eye on them, watch your temps, if they get really hot quickly then stop charging. I've never had any issues charging NiMh packs at above 2amps. Try 1a for now and see how it goes.
                        • mappo
                          • Feb 2010
                          • 496
                          i have sanyo 2700 mah for 4 years now, and i never charger higher than 200mah
                          Do you know what the biggest problem with the world is?
                          That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
                          • 785boats
                            Wet Track Racing
                            • 3423
                            I'm with Mappo on this AA & AAA batteries shouldn't be charged at over 0.5A.
                            I charge all my AA 2500 NmHi cells at 0.4A.
                            Charging at higher rates will shorten their life span.
                            Cheers.
                            Paul.
                            • Smoothops
                              • 142
                              Thanks for the input guys..
