HK Apparition Drive system question
  • Wade
    • 101
    Anyone have any experiance with getting the Prop shaft out of the brass tubing? I can get the Flex cable out from the inside by removing the motor but the Prop shaft seems to be "stuck" or if that is the way it is suppose to be then it's good to go....just use to my Spartan and UL-1 being able to remove the entire system.
  • Diesel6401
    Memento Vivere
    • 4391
    You have to remove the strut and push it out threw the front.
    - Diesel's Youtube
    - Diesel's Fleet
    • 6sHyper
      <<<Surfs up!
      • 640
      You have to remove the strut to get the drive shaft out, it removes from the back side/hull side.
      • Wade
        • 101
        Thanks guys!
