What options do I have?
  • Diegoboy
    • Mar 2007
    • 7444
    I need a set of the "Mini Hydro Hardware" for one of my projects. It's on hold, but I'm doing the research for it now.
    The Micro HW as stated on OSE is...
    Originally posted by : OSE Store
    .094 Flex Cable with 3mm propeller shaft
    Link
    The Micro HW as stated on MiniCatRacing is...
    Originally posted by : MiniCatRacing
    3mm Flex shaft 4mm prop shaft
    Link
    Now that I'm totally confused, and have successfully confused you too, I have a question. (or two)
    I have a .098 Octura flex cable with a 1/8 shaft.
    Will the strut work with my cable?
    If, NO. What strut can I use?
    Are there any metal props in 3MM (or is it 4mm)?
    Do you have any other suggestions for HW to use?
    *note: I want to use the 1/8 shaft in order to use metal props.
    *note: It is for the Pro Boat Mini-cat.
    Thanks guys!
  • Diegoboy
    • Mar 2007
    • 7444
    The stuffing tube isn't set in place, nor it it cut to length yet. It won't stick out like that when I'm done!
    • Mich. Maniac
      • 1456
      what is 3mm in inches.. .118 I believe. So about a .020 difference. You should be ok using that with the strut you want. 1/8 prop shaft is .125 so you should have clearance
      • Diegoboy
        • Mar 2007
        • 7444
        So is it 3mm as listed on OSE?
        ...or is it 4mm as listed on MiniCatRacing?
        • Mich. Maniac
          • 1456
          ok and yes your cable should work with the 3mm strut, I sure dont see many if any props for 3mm though
          • Steven Vaccaro
            Administrator
            • 8934
            Let me help, Its not 4mm :D
            Steven Vaccaro
            • Diegoboy
              • Mar 2007
              • 7444
              Thanks Mich. Thanks Steven!
              • Diegoboy
                • Mar 2007
                • 7444
                Steven, I'll be placing an order for that HW and a few more things. I just have to play "catch-up" first
                • Meniscus
                  Refuse the box exists!
                  • Jul 2008
                  • 3312
                  OK, it seems there's still a conflict of info on this subject:
                  Is it 3mm or 4mm?
                  Specs on Minicat Racing website shows 4mm: http://www.minicatracingusa.com/specs.html
                  Specs on OSE website shows 3mm: http://www.offshoreelectrics.com/products.php?cat=51
                  So has anything changed or is the Minicat website wrong?
                  And while we're at it, if it is 3mm, what size shim is everyone using to get to 1/8"?
                  Thanks for the input!
                  • egneg
                    • 4759
                    If the strut is 3mm or .118 and your drive shaft is .125 you will need to ream out the strut to get your cable to fit or use a different bushing. If the strut is 4mm or .157 you will need to sleeve it to .125 to use it.
                    IMPBA 20481S D-12
                    • Diegoboy
                      • Mar 2007
                      • 7444
                      Egneg, I think he is asking, since a discrepancy has been identified, why has it not been corrected? If not, Meniscus, would you elaborate for us?
