I just got my 2 11.1v 6.5a 75c(150c) batteries from MaxAmps.com today, put them in my boat and took it to the lake.
I couldn't get over 5 mph. Turns out, even after everything was seriously tight... The flex cable was stripped smooth as a babies bottom. It would still turn the prop at low throttle, but open it up and you go nowhere.
I bought a new stock flex drive and collet from traxxas, I got it installed, tested it inside my house on the stand, and it stripped again. ON THE STAND.
Someone said I may have gotten grease on the cable where the collet meets. I didn't. I've even made it a point to take everything out of the boat and clean the in commercial degreaser before running it. And again for the replacements.
So I'll try one of the drive systems on OSE
I saw quite a few flex drive assemblies around OSE, which one is right for my Spartan?
I've got a prather 230 on the stock motor and esc but everything is super cooled, 2 transom pickups, 2-2 inlet under-the-hull pickups, and the stock water pickup with 4 water outlets. Someone joked with my about all the pickups causing tons of drag causing the torque from the motor to strip the drive.. whatever.
