Swordwish 200 ?
  • Brushless01
    • Apr 2010
    • 489
    Swordwish 200 ?
    Hi guys im having trouble with my Delta force 29 im running a Feigao 8xl and a swordfish 200 now the problem is when i let off the throttle it carries on for about a second and its really annoying is there a cure for this ?
    Thanks
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Steven Vaccaro
    Administrator
    • 8934
    It should be for less than a second. But it can seem like an eternity if you are close to something. There is an update that is said to address this.
    http://www.offshoreelectrics.com/dow...2011-04-27.zip
    Steven Vaccaro
    • daveives
      • Jun 2009
      • 111
      ESC saver feature?
      It could well be that this is a safety feature designed to protect the ESC when a sudden "zero throttle" setting occurs. I have done some preliminary calculations and measurements that indicate a large current/watt surge can result from the transfer of the boat kinetic energy thru the prop when going from full throttle to zero throttle too quickly.
      The calculation follows: (assumes 100% energy transfer efficiency to ESC)
      WATTS=328*WEIGHT/(DELTA TIME)*(HIGH SPEED/60)**2*ln((HIGH SPEED)/(LOW SPEED))
      boat WEIGHT in pounds
      DELTA TIME in seconds between high speed and low speed (from GPS)
      HIGH SPEED and LOW SPEED in mph
      ln is natural logarithm
      result is in watts
      Example:
      5 lb boat
      60 mph high speed
      30 mph low speed
      .25 seconds delta time between high speed and low speed
      type in GOOGLE search box
      328*5/(.25)*(60/60)**2*ln((60)/(30))
      result in watts is:
      ((328 * 5) / .25) * ((60 / 60) ** 2) * ln(60 / 30) = 4,547.
      initially at 60 mph, dropping quadratically to 1136 at 30 mph.
      I will bet that this stirs up a hornet's nest!
      • LiPo Power
        DJI Drone Advanced Pilot
        • 3678
        Canada
        • jamie
          • May 2011
          • 206
          How was it programmed ?
          The program card info can be downloaded for reference, sounds like you have some soft settings in there, I think a program card is only about $6.00 if you dont have one.
          • Brushless01
            • Apr 2010
            • 489
            Thanks guys i will try the update ! Also i already have programmed the esc.
            • sailr
              • 7128
              I programmed mine with the card and set for soft shutoff. I thought that was only for when the LVC kicks in? Mine has the same problem....runs on for a bit after letting off the throttle. I'll try using the hard cutoff. I don't have the USB connector for the esc so downloading an update isn't going to help me.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • sailr
                • 7128
                Anyone tried the update yet?
                Mini Cat Racing USA
                • jamie
                  • May 2011
                  • 206
                  My program card is set at
                  1 ON FOR 12V LVC
                  2 OFF
                  3 OFF
                  4 ON
                  5 ON FOR CLOSE BRAKE
                  6&7 ON FOR 0/15 TIMING as2650kv leopard an agro motor combo for a UL1 LOL
                  8 OFF FOR SOFT SHUTOFF WHEN REACHES LOW VOLTAGE
                  9 ON
                  10 OFF FOR STANDARD START BUT I HAVE USED ON/ON FOR SOFT START
                  11/12 ON FOR 8 KHZ
                  Sorry im not a computer wiz so cant help you with updates but this program works well on mine and seems to be reliable ive had to shut it down pretty fast a couple of times when ive run out of room
                  • sailr
                    • 7128
                    Interesting. Same settings I'm using and it has the run-on problem when going to low throttle.
                    Mini Cat Racing USA
                    • Insaniac
                      • 496
                      I'm running this V2 Swordfish 200 software (3-7-2011) and it still tends to run-on for about 1/2 second...not sure if it's fixed...
                      Support US hobby suppliers
                      • jamie
                        • May 2011
                        • 206
                        Hmm not sure but ive got the same brand esc on 2 hydros with the stock UL1 tactic x240 and spectrum Dx3e setups and they both work great .... Am too dumb and new to this stuff to help out much more
                        • DINO7
                          • Jan 2009
                          • 165
                          @sailr
                          ask from Michelle at HIFEI to send you the new firmware for 200A esc.i upgraded mine and no problem now....it stops normally..
                          H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                          MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                          BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
                          • Steven Vaccaro
                            Administrator
                            • 8934
                            Originally posted by DINO7 View Post
                            @sailr
                            This should contain the latest firmware
                            Steven Vaccaro
                            • Insaniac
                              • 496
                              FWIW, the last 4 digits of this firmware are 2000; the previous version was 200L.
                              BTW, this latest version seems to also have a throttle delay of about 1/2 to 3/4 sec. when you chop the throttle.
