Mini Vid Cam Housing & Test
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 421
    I purchased a Key Chain Style Video Camera from FleaBay that records in 720p X 480p (HD?) format to capture on-board vids.
    I constructed a waterproof enclosure using a 1-1/2" PVC slip coupler & cap plug. The window glass (plastic) was from an old microwave oven door, which was attached to the coupler using 3,000 PSI marine (cures under water) epoxy. The base is 1/8" 5 ply plywood, secured with a 10-32 flat head machine screw & 30 minute epoxy. The base has 1/16" thick silicone rubber 'feet' glued on to prevent scratching a hull when taped in place.
    Pics & a Test Vid . . . .
    Oops - - video doesn't load correctly
    Another attempt . . . .
    • 9481
    Great idea man!
    I have one of thes cameras and need it waterproof
    I just have no idea how to get the time code off the lower right corner
    • FloatDaBoat
      • Sep 2009
      • 421
      This is the Ebay link for the camera I purchased.
      http://cgi.ebay.com/HD-Key-Chain-Recorder-DVR-Video-Camer-Webcam-30fps-11-/160527201041?_trksid=p5197.m7&_trkparms=algo%3DLVI %26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clki d%3D8858223352141438593
      It states the resolution is 1280 X 720p HD recorded in .MOV format. I converted it to 720p X 480p in .WMV format. If this is the same vid cam you have, I've got the firmware required to delete the date/time stamp (supplied by the seller).
        • 9481
        that looks like the one!
        • FloatDaBoat
          • Sep 2009
          • 421
          Brushless55
          If you want the firmware, PM me with your Email address.
