Prince 25 running issue
  • Brushless01
    • Apr 2010
    • 489
    Hi guy sover the winter i built a prince 25 from a bare hull upwards here is my setup :
    HOR Prince hull
    Aquacraft supervee 27 hardware
    Ammo 2300
    UL1 ESC
    2x 2s 5000mah zippy lipos
    No trim tabs or fins
    And the motor is mounted 3.5 inches from the transome
    Running either a x637 or a 42x55 prop
    Anyway my problem is that the boat is very flighty and hard to drive anything over 3/4 throttle it just flips over. Also it hops very badly in the turns .
    What I was wondering is if any of you guys could help me to get this boat running nice and fast without flipping and hopping ?
    Thanks
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • b.mcdaniel.2009
    • 1872
    Sounds like you need to add the tabs and fins.
    Trim tabs will help keep the nose of the hull in the water depending on how they are adjusted.
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
    • Brushless01
      • Apr 2010
      • 489
      The thing is tho i cant get tabs to fit on the transome !
      • martin
        • 2881
        Why cant you get tabs to fit, All the rtr Prince, Rocket,DF hulls come with tabs & fins.You may have to buy the right size tabs but they will take tabs unless you have done something different on the transom in your build. Martin.
        • Brushless01
          • Apr 2010
          • 489
          I can get some tabs on but not my adjustable ones.
          • keithbradley
            • 3671
            Turn fins are meant to eliminate the hopping in the turns, so that will fix that. Trim tabs are used more to stabalize the boat. If it chine walks, or rocks back and forth at high speed and that is the problem, trim tabs should take care of it. Theyre not really meant to keep the hull from blowing over though. If its just going over backward your COG is too far back or your strut/stinger is not properly adjusted. Where is your COG currently?
            www.keithbradleyboats.com
            • JackBlack26
              • May 2007
              • 904
              I can't imagine my prince without at least turn fins. It would be unusable!
              • Brushless01
                • Apr 2010
                • 489
                Thanks guys im going to install some turn fins and trim tabs. It also chin walks very bad so hopefully the tabs will eliminate that.
