I upgraded my AquaJet to a Sv27 motor/ESC...
  • Dark Side
    • 3
    And in the process found that the coupler had a stripped out set screw. I drilled out the screw, pulled off the coupler. Took the Cen Ujoint and drilled the shaft to fit the SV27 motor, and then found out that I had drilled it off center.
    Now I need a new coupler, can I use the "cen-bj21" or do I need a different one?
  • Steven Vaccaro
    Administrator
    • 8932
    bj21 is the stock replacement. This is better.
    http://www.offshoreelectrics.com/pro...rod=ose-flex54
    Steven Vaccaro
    • blakybob
      • 131
      So how's the sv27 motor/esc working out in the AJ? How are you powering it? I was thinking of breathing some life back into mine and that looks like a good way to do it.
      Blake
