Whiplash/P Sport Hydro
  • Chilli
    • 3204
    Have you tried a strut (a bit positive) or trun fin adjustment to settle the boat down? On Tonys recommendation we run the 545 with a degree positive on the FE30 and the rear stays planted. I'm a newbie at sport hydros so I'm trying to learn set up but I think they are quickly becoming my favorite.
    Sailr, I take it you're not using a Aquacraft controller in your spec set up? I am and I'm afraid to use anything bigger than a 442 at the moment. But I have Mr Sholund working on some ABC 17xx props for me.... and some 18xx for Neu power.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • detox
      • 2357
      My strut is dead flat on the setup board. I am trying different props first then I will try strut angles and other ideas (cog). The biggest speed improvement so far was using the steeper ride pads. The higher discharge Hyperion batteries help LOTS also.
      • detox
        • 2357
        I have used some aggressive props (ABC H 10 and S 15) with my spec Raptor rigger (UL-1 esc and motor). I can tell that the motor will be the first to go. I am still using the original UL-1 esc with larger capacitor.
        • detox
          • 2357
          The ABC 1816/3 prop is difficult to sharpen and balance, but well worth the effort. Requires different strut setting and/or more weight added to stern to keep prop in water .
          • Mel279
            • Dec 2008
            • 873
            #35
            detox
            got any video's?mine will be coming soon, interested on the ride pad, how do you make them and where do you attached it?
            regards
            Mel
            Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
            • detox
              • 2357
              #36
              I cut the 1 degree ride pads from a block of bass wood using a table saw. Then finished them using finishing epoxy resin. The ride pads will make Whip faster, but more weight is needed to prevent it from taking flight. I would first try the boat without ride pads. Unless using the lower powered ul1 motor/esc. Sorry no video.
              • sailr
                • Nov 2007
                • 7128
                #37
                Yes, I am using the Aquacraft controller. No problem with the M445 prop.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • detox
                  • 2357
                  #38
                  I am not so sure about Mr. Sholund
                  • Mel279
                    • Dec 2008
                    • 873
                    #39
                    can you make me some?
                    • TheShaughnessy
                      • 1461
                      #40
                      using a ul1 motor with m445 in a 29 inch cat and pulling 104 amp peaks, couldn't tell you the continuous though, wish i could.
                      • Mel279
                        • Dec 2008
                        • 873
                        #41
                        hi Guys
                        My whiplash came today, I setup using 1515 1y, (4s)2 x 2s 25-50c 5000mah nanotech, skywing 200A and my available props are x442, x447, k45. What timing should I set for the esc and what available prop that I have would you recommend? Im new to this kind of boat.
                        thanks
                        Mel
