genesis rear strut ?
  • Shaun78
    • Feb 2011
    • 419
    I took it apart to clean and replace the 4mm bushings. Well the 4 mm bushings have are smaller OD and allow the rear prop shaft to slide right thru the strut. I reused the old ones, at least they hold the rear shaft. So now what if i needed to replace those bushings? the older ones fit tight in the strut and the new ones slide right thru. Why? also should i be able to move the stuffing tube in and out? mine looks epoxied in but i could still move it.
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • dano1
    • Dec 2010
    • 439
    shawn, sounds like the epoxy is there but not getting a grip on the tube, it fell out on me before and i glued it back and forgot about it, water was comming in the gap there.Hows the genny treating you????
    • crrcboatz
      • Jan 2009
      • 1103
      My local ace hardware has a decent selection of bushings but they will not be metric ID.
      Almost any local bearing company will have what you need in metric od and id.
      They will probably be oilite which I like better anyway.
      • Shaun78
        • Feb 2011
        • 419
        Dano's, it only moves a little with some force. If I leave it alone it's good...I took it all apart and greased the rear strut....treating me good....60.5 mph and climbing. I've been mess in with the Spartan lately.
        • Shaun78
          • Feb 2011
          • 419
          Anyone replaced the 4mm stock strut bearings in a genesis? If so where did u get the correct ones that fit snug in the strut?
          • Shaun78
            • Feb 2011
            • 419
            Dan, was it epoxied in or the shoe goo?
            • tunnelvision
              • May 2010
              • 819
              I used the octura ones. Just one bushing actually and its held up very well on my setup (2150kv leopard, 180 seaking, M445. Kintec also sells the whole replacement assembly with a 3/16th strut.
              Go Fast...Turn Right...
              • Diesel6401
                Memento Vivere
                • 4391
                Yes. you have 2 options.
                A) remove both 4mm bushing and install a 3/16 speedmaster bushing. I used this one on my genny, http://www.offshoreelectrics.com/pro...s-spds-014-bsf I cut the it to the proper length used a small dap of ca around the end and pressed it against the strut. It slightly extends the strut so make sure you flexshaft is long enough.
                B) after using the first method I then started fully replacing the bushing and this is the method I prefer. takes more time but I like the finished product better. Grab some .187 teflon bushing (i gotmine from aero-marine). Remove the 2 4mm bushing remove the sturt place the strut in a vise drill dead center of the strut with a 1/4 drill bit and press the new bushing in. You have to drill DEAD straight and the proper depth. If you do it right it comes out super clean.
                Here's the idea: http://forums.offshoreelectrics.com/...0&postcount=41
                http://www.aeromarinerc.com/index.ph...hk=1&Itemid=53
                - Diesel's Youtube
                - Diesel's Fleet
                • dano1
                  • Dec 2010
                  • 439
                  epoxy shawn, thats not shoo goo, only thing i shoo gooed was esc for easy removal if i needed to update brother
                  • deuss
                    • 2
                    Hello,
                    just a quick question, as my original prop broke last week im looking for the same, which one do i choose?
                    Any tips??
                    Regards
                    Nikk
                    • Shaun78
                      • Feb 2011
                      • 419
                      Octura x642
