4MM collet from Kintec,wrong one
  • Shaun78
    • Feb 2011
    • 416
    The prop end is too small. where can i get a 4mm drive dog with ears that will fit a regular prop?
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • G1ST
    • Dec 2010
    • 348
    If you want to use 3/16 props you can make a bushing out of 3/16 OD brass tube.
    Steve sells the tubing or bushings pre cut
    Greg
    • Shaun78
      • Feb 2011
      • 416
      I have bushings but the 4mm drive dog prop ears are to small. I need a stock genesis drive dog.
      • G1ST
        • Dec 2010
        • 348
        Gotcha
        If Steve doesn't have a 4mm Drive Dog Ben at Fightercat does.
        • Shaun78
          • Feb 2011
          • 416
          I just hope they have the 4mm dog with ears to fit regular octura props
          • G1ST
            • Dec 2010
            • 348
            I see what you are saying.
            I'm building a Fightercat Daytona with FC hardware. I have a X445 bolted up and the teeth of the drive dog are thinner than the notch in the prop. The teeth do go the full depth into the prop and when the prop nut is tight it doesn't move at all.
            I haven't run it yet so I can't say if the fit will be a problem or not. I'm sure others have been down this road before.
            We'll see.
            Maiden coming soon.
            Greg
            • Shaun78
              • Feb 2011
              • 416
              I hear ya...the one on my genesis now is a perfect fit.
