Hit 60 mph on my genesis today...
  • Diesel6401
    Memento Vivere
    • 4391
    Originally posted by Shaun78 View Post
    My poor friend bosnicali lost a boat today....maiden voyage, was running good and then hit a wave or flipped and then splash, went under and we figured no big deal but it never came up.. Had foam in the front too but still sank..
    Originally posted by dano1 View Post
    Thats the genesis i built dale, he is working bugs out of it, i told ya that boat will turn some good times, with the thru hull pickups i know its slowing her down some, some more adjustments and she will fly
    Yup she scootrs alright. I think the Genny like higher rpm lower prop diameter and more pitch which is why the x642 turns some good numbers... Well thats just my experiece with the Genesis...
    well i blew everything out the ass end of the kos on that pass shaun.....and it was updated stuff.......now its back to square one on this dam thing, didnt loose the props thanks to couplers on prop shaft
    What happened?!?!? Electronics didn't go poof did they?!?
    - Diesel's Youtube
    - Diesel's Fleet
    • Shaun78
      • Feb 2011
      • 419
      Diesel, that makes sense....60 is moving for sure..... Dan, the mono was running an m445 on 4s and hitting about 43mph.
      Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
      (63.7 MPH) Traxxas Spartan (same setup)
      • 6sHyper
        <<<Surfs up!
        • 640
        Gibbies, I haven't used hatch tape on my genesis...I'm afraid of the clear coat peeling but I'm trying to see if hockey tape or the hatch tape from ose will peel the clear coat. I guess clear coat peeling is better than loosing an entire boat
        Just use black electrical tape, trust me it wont peal the clear, you should definately tape the hatch.
        • ron1950
          • 3082
          hockey tape will take the fiberglass off lol.....that stuff really stick hard...try proboat tape....it sticks well but wont destroy paint and decals....
          wha hull did your friend lose? fore what i have in my boats....id swim for it if the water were clear enough....down here in mississippi the water vis is about 3 inches
          • dag-nabit
            • Feb 2011
            • 775
            Dagnabit...the problem with larger props is that the prop will hit the strut so u need to angle it down and that looses speed.....keep me posted, just got mine so let me know what u do and upgrade? Dan, that stinks. What broke?
            Will do, just shipped, and with the holiday weekend and international shipping, could be a couple weeks before I see it.
            The M447, M445 and P225 are all props that were suggested by Ben at Fightercat, so we will see. I'm new to cats, so there is going to be a learning curve.....
            I will be happy with stable running in the mid 40 to 50 range.
            Kevin
            • gibbies_03
              • 71
              never had any problems with electrical tape so Im gonna stick with that...def glad we put the extra foam in the front of the boat...helps with handling too...round two will be in havasu this wknd with the big motor and smooth water at 630 am...
              • iamandrew
                • 576
                Ive just taken out my genesis this afternoon , ran quite well
                Bought 2 props from kenetic racing, sanded them down, but i dont know if they are "balanced" but they look pretty good now, one was a X642, the other was a 440/3
                im supprised about the 3 blade prop. Next time i take it out ill try and get hold of a GPS, but the smoothness of the 3 blade was instantly noticable, hardly threw up any wash, and definatly picked up after the first 10M, i swear the whole boat was quieter as well! I couldnt visually tell the difference in speed with the two props though
                • dano1
                  • Dec 2010
                  • 439
                  the stinger on left rear came apart at prop, the bearing worked its way out, this is updated stuff too, gonna look it over a bit more to see what happened, but she sure scoots on 4s and great roostertail, need to take some steering out of rudder,little touchy on turns, this boats handles so much different now with the batt relocated. I like the boat now....lmao
                  • b.mcdaniel.2009
                    • 1872
                    Any video of that 60mph....?
                    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
                    • b.mcdaniel.2009
                      • 1872
                      Originally posted by Diesel6401 View Post
                      Actually you may find more speed with the x642 over the m445... sometimes it's all about the pitch
                      Try a x645. should pick up a few MPH there and should be okay on temps as well......M445 is way to small for that 37" hull IMO.
                      • dano1
                        • Dec 2010
                        • 439
                        i got 60s pretty easy with that boat, im not sure if i have a vid on you tube of it or not, but I have one running 60.....oh....yes....thats my old boat, he is having a blast with her
                        • dano1
                          • Dec 2010
                          • 439
                          i do have a vid on you tube running the same boat when i hit the 60s, its danogti if ya wanna check it out, lot left in the motor, she was barely bustin a sweat, shaun just needs to get the bugs outta her and he is on it
                          • Shaun78
                            • Feb 2011
                            • 419
                            I had a run yesterday over 60 for sure, no gps inside but it was moving......
